SoCal Sprinters
KG Plastics - FB
Water temp drop through radiator
Goto page Previous  1, 2
Allan Litten
PostPosted: Thu Oct 11, 2012 5:58 pm    Post subject: Reply with quote
I have read somewhere that the water pump takes 0.3 hp to run at max rpm but I cannot remember where I read it.
Was that you Ian?
Ian Harrison
PostPosted: Thu Oct 11, 2012 10:30 pm    Post subject: Reply with quote
Hi Guys
If you look at an electric pump that does the same job you can more or less imagine the figures for the engine pump.
I've used this exact pump and it's awesome!!
http://www.demon-tweeks.co.uk/motorcycle/water-pumps/davies-craig-ebp-electric-water-pump
click on specification and benefits:
Voltage 9-15V
Max Current 1.3 Amps
Max Wattgae - 19.5Watts
19.5 watts = 0.026 horsepower
i.e.e Not a lot!!
Even this monster only draws a max of 7.5 Amps = 112 Watts = 0.150 horsepower
http://www.demon-tweeks.co.uk/motorcycle/water-pumps/davies-craig-ewp80-water-pump
Is that better Andy Wink
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
www.viper-racinguk.co.uk
sales@viper-racinguk.co.uk
+44 7984 225 564
+44 161 343 2009
Andy Kiker
PostPosted: Fri Oct 12, 2012 5:49 am    Post subject: Reply with quote
Glad to see you are back on top of things Ian.
That pump you listed was a little slow for us. We went to the one I list below. It draws more juice but has much better flow and is cheaper.
Cheers! Very Happy
http://www.siliconeintakes.com/product_info.php?cPath=12&products_id=1001&osCsid=5470a83850cc182863db156fb6b704dc
Not sure how I did the double post? Embarassed
Andy Kiker #24
Anderson Karts
WiWa GasGas
Powrpad
Ian Harrison
PostPosted: Fri Oct 12, 2012 10:01 am    Post subject: Reply with quote
Cheers! Very Happy
Hi Andy,
Yours falls between the 2 that I listed (I added the monster to the post later)
So your pump takes 3.5 amps x 12 volts = 42 Watts = 0.056 Horespower
Nice price as well!!
So the league table (US Dollars and Litres per minute is as follows):
1. Ian's Small Pump - 15 Litres per minute - $135.05
2. Andy's Medium Pump - 20 Litres per minute - $119.99
3. Ian's Monster Pump - 80 Litres per minute - $250.28
Translation
British Litres = US Liters
US Decimeters cubed (0.1M x 0.1M x 0.1M) = 1000cc = 1 Litre (Liter) Wink
Looks like Andy's wins todays prize for value for money! German engineering too, to match the GasGas Cool
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Greg Lindahl
PostPosted: Fri Oct 12, 2012 11:47 am    Post subject: Reply with quote
Still want to know: What's the temperature drop from rad in to rad out, for any application. A round figure would help... I'll know after the Sonoma race on T'day weekend but I'd sure like to know now.
Ian Harrison
PostPosted: Sat Oct 13, 2012 4:49 am    Post subject: Reply with quote
Hi Greg
Best I can give you off my dyno this morning is 55 deg C in the normal top hose temp sensor towards the back rad and 35 deg into the engine water pump (Anderson/CR250).
I put the second temp sensor into the bleed screw hole on 'U'-Pipe that feeds into the intergral pump inlet (CR250).
However, this is a twin rad setup (rear and side) and the cooling is nothing like as good on the dyno as it is on the racetrack at speed.
Obviously as the engine gets hotter and the ambient air gets cooler, the temperature gradient gets steeper and heat transfer is more rapid.
Best I can do in the time. Hope it helps Very Happy
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
+44 7984 225 564
+44 161 343 2009
Greg Lindahl
PostPosted: Sat Oct 13, 2012 7:45 pm    Post subject: Reply with quote
Thank you Ian.
That's very helpful. A 20C increase while passing throught engine is quite significant, and the infeed side is quite cool. Both load size and how cool the return water is are interesting...
Erik Maxfield
PostPosted: Tue Nov 20, 2012 10:29 pm    Post subject: Reply with quote
.02
I was thinking strongly about adding restrictions to the outlets of my 125 a couple of years ago. I was thinking primarily around reducing pumping losses (horsepower to drive the pump. I made some REALLY conservative calcuations around hydraulic horsepower and found that it was a silly pipe dream.
Adding restrictors in the return lines backs the pump on the curve and keeps it from cavitating (with an increase in RPM or a decrease in backpressure the flow goes up- the Net positive suction head required (NPSHR) of the pump goes up with increased flow rate)
That said,
I run with a giant barndoor in the wind (roadracing a 125) and was strongly considering building a diffuser box on the inlet side of the radiator to better reduce parasitic drag (much like most of the 250 brigade out here runs). That should help for a couple of MPH for use (we run into a wall around 106-108 MPH).
Erik
The early bird gets the worm.....
The second mouse gets the cheese....
Stock CR125.
Chassis-FrankenKART
Intrepid/ITAL combination
PostPosted: Wed Nov 21, 2012 5:23 am    Post subject: Reply with quote
Cheers! Very Happy
Hi Andy,
Translation
Best Regards
Ian Very Happy
I'm guessing you guys aren't running alternators? So the HP required through the wattage calculation is a mute point, or do you figure the stock water pump is using that much HP to spin the pump or more? Just thinking at .056hp, can that even be measured on the dyno?
Just thinking out loud here folks....
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Greg Lindahl
PostPosted: Wed Nov 21, 2012 3:11 pm    Post subject: Reply with quote
Hi Erik and thanks for the ME input WRT pumps, cavitation and losses: THAT explains why I found what was noted in the message above about choking flow and reducing temperature while experiencing no performance improvement.
On the subject of aero drag from the radiator; I've tested many inlet/outlet ducts to no real affect. However, I'm not finished with ideas and will continue testing until I either find a measureable drag reduction or determine that it's not worth the effort.
For this weekend, I have the radiator in full parachute mode and am gathering data for a winter project looking for an improvement in drag loss.
Come chat in garage 10...
Greg
Erik Maxfield
PostPosted: Wed Nov 21, 2012 9:49 pm    Post subject: Reply with quote
Greg
Sniffed me out, eh?! (Actually my day job is a rotating equipment engineer in a refinery- AKA pumps, centrifigual and recip compressors etc). If you really want, here are the affinity laws (which are useful for relating flow to RPM and what happens when you increase RPM to flow... http://en.wikipedia.org/wiki/Affinity_laws)
For your ducting stuff, you have not noted increases in terminal velocity (or the time that it takes to get there) with ducts on the inlet side of the cooler? I was very interested to see if there would be a increase in cooling efficiency by slowing the air down (and eliminating spill over the side) relative to a "naked" radiator in the wind stream. I willl be pitting in the garages so I will be over. I am #23 in stock moto.
For all others, sorry about the tangent. I tried to hide it with some technobabble about pump laws at least?!
Erik
Stock CR125.
Chassis-FrankenKART
Greg Lindahl
PostPosted: Thu Nov 22, 2012 12:44 pm    Post subject: Reply with quote
I'll be measuring flow speed at the backside of the radiator on Saturday. Would like more channels on my Evo IV so more measurements could be made. I measure five temperatures and that isn't enough and must move the inputs around to gather all I want and still miss some...
See you Saturday, and, we've met a few times before.
Jeff Pickel
PostPosted: Sat Feb 09, 2013 9:18 am    Post subject: Reply with quote
you would be surprised on the cylinder jacket pressue with out a head gasket and with one. It depends on your overall system set up.
Page 2 of 2
DB time: 0.203532 (62.31%), total time:0.326624, queries:38
