Mike Svorinich
Joined: 30 Dec 2009 Posts: 126 Location: United States, Florida, Newberry
Posted: Wed Sep 26, 2012 7:29 pm Post subject: |
If you're running a fuel pump and your float needle doesn't have a rubber tip, thats your problem.
Metal tip float needles are made for gravity fed systems with almost no fuel pressure.
I believe what you are looking for is a viton tipped needle.
I got mine from a carb store who said it was for a snow mobile. LOL
I run about 4.5-5 psi with no leaks.
hope this helps _________________ '92 Haase shifter
(old) '85 yz250 engine
Restoring to running condition |
Tom Barth
Joined: 22 Oct 2001 Posts: 1379 Location: United States, Michigan, Waterford
Tom Barth
Posted: Fri Sep 28, 2012 5:31 am Post subject: |
Delete _________________ Tom Barth
http://www.greenflagkarting.com/
Power is good...more power is better... too much power is just right! |
Tim Salvino
Posted: Fri Sep 28, 2012 10:07 am Post subject: |
| Thanks, I've got one on the way! Will I need a "T" in the line from the pump to the carb? Or can I run it just straight in to the carb? |
Steve Buckner
Posted: Fri Sep 28, 2012 10:26 am Post subject: |
| I have mine ran from tank to filter, filter to arrow in on pump, arrow out on pump to carb, Pulse line to barb fitting in reed manifold. Thats it. I installed mine on the right side of seat, attached to seat strut with rubber mount. Tuck it back so your elbow will never hit it. Mount the pump with the pulse line at 6 o-clock. Very clean and simple. |
