2D2W - LB
RLV - SS
SCCA Enterprises - FB
Oil and Ratio for IAME tag 60
PostPosted: Tue Sep 18, 2012 7:09 pm    Post subject: Oil and Ratio for IAME tag 60 Reply with quote
Does anyone know the type of oil and ratio for the Easy Kart IAME TAG 60?? Book says 16: 1 but only refrences ordinary 2 cycle oils. I'm wondering it it would be the same ratio with a synthetic.
PostPosted: Thu Sep 20, 2012 10:08 am    Post subject: Reply with quote
The more oil you can use without fouling the spark plug the faster you will go. 16:1 is a good ratio for almost all kart engines. Don't get your oil from walmart, I suggest using Red Line Two Stroke Kart Oil but any high quality RACING oil will work.
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
PostPosted: Thu Sep 20, 2012 2:42 pm    Post subject: Reply with quote
Why would you think more oil makes you faster? Rotax is 50:1 synthetic aperantly these are 16:1 castor.
PostPosted: Thu Sep 20, 2012 7:43 pm    Post subject: Reply with quote
So, a model airplane engine uses 4:1 castor (the thick castor right out of the bean) and turns 40,000 rpm on a full wave pipe.
Rotax uses 50:1 synthetic because, it goes 50-60 hours between overhauls and they don't want carbon build up, not because it's faster.
This subject has been covered before, try the link.
http://www.ekartingnews.com/viewtopic.php?t=22724
Gif Cool
PostPosted: Fri Sep 21, 2012 4:51 am    Post subject: Reply with quote
I'm not suggesting more or less oil makes you faster because I don't know. I'm asking you why you believe more oil increases power? Whats going on to increase power? The link doesn't explain it either.
Greg Wilkinson
PostPosted: Fri Sep 21, 2012 4:23 pm    Post subject: Reply with quote
More oil makes more compression and to quote Al, "Compression is the Holy Grail" Cool
Greg Wilkinson
Driver-Angel Wilkinson
"Tag" Team Wilkinson
Kosmic T-11 - Comet Leopard
PostPosted: Sat Sep 22, 2012 4:45 am    Post subject: Reply with quote
Thanks guys sounds logical. I'm going 16:1 Burris castor. That seems to be what most are using in these engines.
DB time: 0.140833 (43.2%), total time:0.326012, queries:38
