Margay Racing
RLV - SS
Steering wheel angle and height ?
Cesar Rull
PostPosted: Tue Sep 18, 2012 10:44 am    Post subject: Steering wheel angle and height ? Reply with quote
Guy I've been googling several pictures of karts and it seems to me that some have the steering wheel more erected that others and some karts seem to have the steering wheel is a shorted steering column.
Is this the case or are these just optical illusions ?
I would like to attach some pictures but I am on a cell phone. Maybe later I will.
Cesar Rull
PostPosted: Tue Sep 18, 2012 12:08 pm    Post subject: Reply with quote
Here are some pictures:
Take a look at this image:
The wheel seems very low profile and very close to the drivers legs.
This is image, also looks very low profile however it seems to me that nose of the car is elevated or of an elevated design?
However this last picture seems like the wheel is both less inclined and taller..
Please provide some insight.
Tyson Henry
PostPosted: Tue Sep 18, 2012 12:15 pm    Post subject: Reply with quote
Preference. You could shorten a steering column, use a different angled steering hub, etc. All about preference.
Cesar Rull
PostPosted: Tue Sep 18, 2012 12:58 pm    Post subject: Reply with quote
this is something I can do all chassis (modern).
I did a quick google for "Kart angled steering hub" and came up with these:
https://www.google.com/search?rlz=1C1CHFX_enUS499US499&sugexp=chrome,mod%3D2&q=angled+steering+hub&um=1&ie=UTF-8&hl=en&tbm=isch&source=og&sa=N&tab=wi&ei=k85YULDOLYOy8ATP9oCACg&biw=1307&bih=542&sei=oM5YUI65NofA9gT7l4HYCw#um=1&hl=en&safe=off&rlz=1C1CHFX_enUS499US499&tbm=isch&sa=1&q=kart+angled+steering+hub&oq=kart+angled+steering+hub&gs_l=img.3..0i24.860126.860842.0.861020.5.5.0.0.0.0.126.530.2j3.5.0...0.0...1c.1.g2tICEeQjx8&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.&fp=bbcf1e1f1e43a878&biw=1625&bih=542
it seems like they attach to the wheel side of the column?
Mark Sink
PostPosted: Thu Dec 06, 2012 9:25 pm    Post subject: Reply with quote
Is there a limit to how low you can lower the steering wheel. I just bought my first kart, and need to lower the wheel, which I realize will cause the front to toe out, and can be adjusted, but is there a limit to what is safe for lowering the column itself? I like it low.
Mark
Newbie, Looking for folks near Raleigh, NC
Matt Dixon
PostPosted: Fri Dec 07, 2012 9:54 am    Post subject: Reply with quote
Mark
Mark
Could you not just reset the toe? If need be you can buy longer (or shorter) tie rods.
If you don't have a front end tool just take a tape measure from the front edge of the rear rim to the back edge of the front rim.
edit- as I reread your post, as long as the Hyme Joints aren't all stressed you can lower to your likeing
Matt Dixon
94y Energy Corse/Swedetech
Dan Haynes
PostPosted: Fri Dec 07, 2012 11:58 am    Post subject: Reply with quote
Why not just cut an inch or so off the top and re-drill it instead of shortening the bottom?
Blaise Haynes
#3 Arrow X1-CIK
TaG
DB time: 0.133424 (43.15%), total time:0.309232, queries:38
