MaxSpeed - LB
Ribtect - SS (non-flash)
Tony Kart/Vortex - FB
Leopard Water Pump
Ian Ashdown
PostPosted: Mon Sep 17, 2012 3:09 pm    Post subject: Leopard Water Pump Reply with quote
Hi,
As part of my routime maintenance I decided to pull my water pump off and clean/lube it etc. I'm a little confused as the impellor turns independant of the drive pully. Am I missing something here, is there a clutch of some description in there? Is this re-buildable item?
Everything seemed to be working fine at the last run so I don't think I've broken anything, I just cant see how the pulley is driving the impellor.
Ian
Oscar Biondi
PostPosted: Mon Sep 17, 2012 9:13 pm    Post subject: Reply with quote
That doesn't sound right. Is there a set screw to fix the impeller to the shaft? Some are just pressed on. I'm assuming you have a serviceable water pump. You can buy rebuild kits for some but not all the kits include the impeller and drive shaft.
http://store.kartoramainc.com/catalog/product/80ad75da83a74d52b3ae0a46e0ae2edf
http://www.cometkartsales.com/store/wildkart/images/wk-pumprebuildkit.jpg
http://www.fastech-racing.com/wildkart-water-pump-rebuild-kit-complete.html
DB time: 0.546302 (77.71%), total time:0.703012, queries:38
