Margay Racing
RLV - SS
AIM MYCRON 4 Issue
Ambrose Buldo
PostPosted: Sun Sep 16, 2012 9:22 pm    Post subject: AIM MYCRON 4 Issue Reply with quote
I have an AIM Mychron 4 on my KPV 100 CC powered Kart. It is connected to an AIM GPS-505 that has worked flawlessly for over a season.
A couple weeks ago the GPS stopped working and imulationously I cannot downlaod data from using the DataKey.
The GPS plugs into a 2 port data hub. The hub is powered by a RC battery. The battery is fully charged. The free port on the datahub is where I plug in the datakey when I need to do a download. Normally I plug in datakey into the free port on the hub, turn the AIM on and download starts. Almost looks like power is not getting to the hub (since both the GPS and datakey get power from the hub), but I checked all wiring and it is intact.
The egt and the IR laptime reciever both work, but these are plugged into the back of AIM unit itself. Not that I think the system needs it, but the 9 V battery inside the AIM display unit is fresh.
Any suggestions?
Ambrose Buldo - AKA Racer27
Old Tappan, NJ 07675
Current: Citation FC2000 (For Sale), Madza RX8, VW Eos
Kart for myself: Intrepid Silverstone Pro w/HPV3 --- With a ROK TAG engine waiting in wings
Kart for Daughter: 2001 Birel ARC-100
PostPosted: Mon Sep 17, 2012 7:31 am    Post subject: Reply with quote
Check with Aim, they have great tech support.
http://www.aimsports.com/support/index.html
Cheers,
Heartbeat Power, LLC.
Mike McKnight
PostPosted: Mon Sep 17, 2012 9:30 am    Post subject: Reply with quote
Ambrose disconnect the data hub and see if your key will download when its plugged into the MyChron4.
Ambrose Buldo
PostPosted: Mon Sep 17, 2012 9:55 am    Post subject: Reply with quote
Thanks for the input. I believe I did this and no change in results. I think the 3rd port (Lowest) on on the back of the AIM was for Data Key and Data Hub Connection. I will try it again just incase I selected the wrong port on the back of the AIM. . If it was just the DataKey not working, I'd buy a new one and be done with it. But fact that the data hub (Which the GPS is connrected to) is dead also leads me to believe it is not just the key.
Mike McKnight
PostPosted: Mon Sep 17, 2012 10:00 am    Post subject: Reply with quote
We would be happy to have a look at your system if you want to send it down to our Virginia office. Normally we can turn repairs around in a day to two. If you would like to do that send it to,
AiM Sports SE
1636 B 9th Street SE
Roanoke, VA 24013-2700
Mike
Ambrose Buldo
PostPosted: Mon Oct 01, 2012 11:23 am    Post subject: Reply with quote
AiM Sports SE
Mike
Shipped out to you today...
DB time: 0.065539999999999 (40.29%), total time:0.162673, queries:38
