Robbie Nelson
Posted: Wed Sep 12, 2012 6:31 am Post subject: Request for a KT100 to World Formula guide |
I plan to switch from a KT100 to a World Formula during the winter break. I would really appreciate any sort of guide, how-to, advice, parts list, etc. on swapping in a WF engine. I'm sure some of you have already made the swap. Thanks in advance!
Note: I'm not looking for a discussion of "x" engine vs WF engine. Please, leave that for another thread. |
Joe Ricard
Joined: 23 Jun 2009 Posts: 869 Location: United States, Mississippi,
Posted: Wed Sep 12, 2012 7:23 am Post subject: |
One thing I found is some 2 stroke chassis won't easily accept a 4 stroke because of the diagonal cross tube being further back on the engine side.
Hits the chain. Seat mount tubes can also be in the way.
Will there be an allowance for a jack shaft like the Burris piece?
Took some fnagling to get the WF to fit Birel C-28 Cadet. custom motor mount. Where the Mini max dropped right in as did the KT-100. _________________ Arrow AX-8/ Rotax Sr. |
Robbie Nelson
Posted: Wed Sep 12, 2012 7:47 am Post subject: |
| Joe Ricard wrote: | | Took some fnagling to get the WF to fit Birel C-28 Cadet. custom motor mount. Where the Mini max dropped right in as did the KT-100. |
I'll be working with a C-28. What do you mean by custom motor mount? I'm sure others will be putting WFs on C-28s. |
Joe Ricard
Posted: Thu Sep 13, 2012 9:23 am Post subject: |
Had to take a 2 piece Burris mount and really off-set it and drill new holes between the plates tap and bolt together.
Most of my fanageling was trying to make it work without starting from scratch. and trying different motor mounts, inclined flat, all sorts. I think the one I finally settled on and drilled is a 5 degree 2 piece Burris.
Clutch gear is outboard the clutch drum and pretty close to the seat and seat stay.
The Gen 5 should provide more driver elbow room as the earlier gen plastic cover is a "real elbow bumper". _________________ Arrow AX-8/ Rotax Sr. |
Brian Garfield
Joined: 04 Apr 2004 Posts: 667 Location: United States, Maryland, SKCA Racing!
Posted: Sun Sep 16, 2012 7:48 am Post subject: |
Or, you could just invest in the perfect World Formula chassis that's won 3 National Championships...
BTW, the seat struts on the Arrow AX-9 4S are located slightly closer to the front (compared to our Kosmic and other chassis) which made it easier for Julian to be very small in a full size chassis.
EDIT: we may hang on to the Arrow for Carson to drive locally, but with the possibility of the Arrow w/ World Formula available in a couple of seasons.
Brian |
Joe Ricard
Posted: Wed Nov 07, 2012 1:35 pm Post subject: |
Bumping this to the top and was wondering what is the weight for JB with restricted World formula
255 ?
or
265. _________________ Arrow AX-8/ Rotax Sr. |
Brian Regganie
Posted: Thu Nov 08, 2012 8:46 am Post subject: |
| 265 with JB restrictor. |
