MG Tires - SS
JA - KT100 vs. World Formula
Goto page 1, 2  Next
Brian Garfield
PostPosted: Sun Sep 09, 2012 8:48 am    Post subject: JA - KT100 vs. World Formula Reply with quote
For those that care, we had an opportunity at the SCCA Solo Nationals to do a true comparison between the the KT100 and Briggs World Formula in SCCA Solo JA class prep. Kevin Teague (2nd place at Nats) was nice enough to offer Julian Garfield a test run in his BWF and since Julian had never driven a 4 stroke before.
This was possibly the best opportunity we've ever had to do a side-by-side comparison. Here are the details:
Driver for both karts: Julian Garfield
Course: Solo Nationals Practice Course
Kart 1: National Championship winning Arrow AX-9/Sean Cook KT100
Kart 2: 2nd Place winning CRG/Briggs World Formula
Weights: 295lbs in BWF (10lbs over) / 310lbs in KT100 (5lbs over)
Process:
Julian ran his KT100 for two runs to set a bar and get used to the course. Unfortunately, the timer didn't work correctly, so we knew he'd have to come back to it. He then jumped into the BWF and ran two runs, the faster being a 28.8xx. He jumped back into his KT100 for one run and ran a nearly identical 28.8xx.
Of course this isn't perfect, but we knew it was possibly the best opportunity we'd ever have. Clearly, at the given weights, the karts are pretty well matched. Longer courses and different types of courses could change things, but at least this gives you an idea.
Joe Ricard
PostPosted: Sun Sep 09, 2012 10:45 am    Post subject: Reply with quote
That's pretty interesting Brian. That's about as good of a comparision as possible.
Congrats on the JA win.
Blueprinted WF?
I guess it falls to the driver and tuner after that. Which is really where the differences are made.
Arrow AX-8/ Rotax Sr.
Chris Teague
PostPosted: Sun Sep 09, 2012 11:08 am    Post subject: Reply with quote
Brian,
Thanks for having Julien try both karts. It's good having this data point. I talked to Julien afterwords about our kart, and it was good getting his feedback.
Joe, the WF motor in our kart was new in late 2004, and we ran it through the 2011 season including Nationals last year, where we realized we were down on power. In Jan 2012 we had Nash's Karts freshen the motor up, and he also found the clutch was shot, so that was replaced also. Both Kevin and Kencey noticed it was much improved after that. It already had the newer ignition upgrade back in early 2011 that comes standard on the newer BWF motors. Kevin being 16, and 5'10' weighed in at around 316lbs or so in our kart, so I'd say the BWF is better if you can be close to the 285 minimum.
Chris Teague
PostPosted: Sun Sep 09, 2012 11:59 am    Post subject: Gearing Reply with quote
A note on gearing: I think both karts were geared as they ran on the east course. So not optimum for the test and tune, but I think they were roughly equally not optimum, and probably not far off perfect for the test and tune.
Scott Boito
PostPosted: Sun Sep 09, 2012 5:24 pm    Post subject: Reply with quote
Great data point. Looks like the weights are pretty close to where they should be for parity.
KM #68 - Haase/Honda kart
BetterOffRacing
Member of the SCCA KAC
Tom Reynolds
PostPosted: Mon Sep 10, 2012 2:02 pm    Post subject: Reply with quote
Keep in mind parity might not be the objective from an SEB perspective. I do appreciate the data.
Joe Ricard
PostPosted: Tue Sep 11, 2012 4:40 am    Post subject: Reply with quote
Wow I am just stunned by that statement Rolling Eyes
Tom Reynolds
PostPosted: Tue Sep 11, 2012 6:07 am    Post subject: Reply with quote
Roll your eyes but that doesn't change people complain about 2 strokes.
Larry MacLeod
PostPosted: Tue Sep 11, 2012 7:14 am    Post subject: Reply with quote
Can I lobby a complaint about the sound of a Dodge Neon with a straight pipe? I think they're way more offensive than 2 stroke engines.
F125 #196
Lefty Funk
Detroit Region
Tim Walsh
PostPosted: Tue Sep 11, 2012 7:17 am    Post subject: Reply with quote
This among other reasons is keeping people from karting.
2002 Birel CR32V/ StockMoto w/PI
Tom Reynolds
PostPosted: Tue Sep 11, 2012 7:25 am    Post subject: Reply with quote
Are we talking adults or children? I'm convinced any adult that says this is just making excuses. We've all heard people say "I wanted to get a kart but didn't for <insert reason here>" that varies from its a 2 stroke to it will hurt my back, etc.
On the parent side, I do believe the 4strokes do allow more accessibility. However if you really want your kid to kart, you'll figure it out anyway right? I talked to many parents at Nationals this year, its interesting that no two sets of them told me the same thing with regards to weights, engines, etc. Everyone has very different outlooks here.
Jason Vehige
PostPosted: Tue Sep 11, 2012 8:20 am    Post subject: Reply with quote
IMHO ... As in my personal opinion.. A 2 stroke shifter sounds great... a KT100 not so much.. But that is not a good reason to exclude the KT as long as FM is around Laughing the one legit argument against the KT from a non parent perspective is their propensity to stall when spun and the fact this requires a starter to be taken out on course, worst case if a WF stalls is to have a worker pull start it (assuming it is not setup to TAG) and they rarely stall. I for one am happy parents still have a choice at all.
If .. Or should I say when I get my Nephews a kart for FJ it will be a WF .... I LOVE 2 strokes but the WF is the clear easy button for me. in B trim the clear choice performance wise and gets the job done in A as well.
thanks for the info Brian.... I appreciate the time and effort you and Chris took to make this happen.
Jason Vehige
05 Vanspeed Sirio / SGM sl204
Tim Walsh
PostPosted: Tue Sep 11, 2012 10:12 am    Post subject: Reply with quote
Did Julian comment on left hand turns versus rights? I know the BMF is heavier, but is it heavy enough to affect the handling?
Chris Teague
PostPosted: Tue Sep 11, 2012 10:19 am    Post subject: Reply with quote
Julien told me afterwords that our kart handled different than his, and the engine powerband took some getting used to.
Kevin had taken one lap at a local event in a KT100 and basically said the same thing about that kart. So I'm sure being used to whatever you have is a good thing.
I didn't ask about left vs. right turns, but maybe Brian has more info.
Julian Garfield
PostPosted: Wed Sep 12, 2012 5:20 pm    Post subject: Reply with quote
I hadn't noticed any handling changes linked to the direction of the turn when driving the WF. Since a lot was new to me when driving the kart, the only way I think you'd notice is if you put both motors on the same chassis. To answer your question, if there is a difference it wasn't big enough to feel immediately.
Arrow AX9-4S/KT-100 - SCCA Solo
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.13037 (37.4%), total time:0.34859, queries:38
