DID Chain
K1 Speed - SS
Tony Kart/Vortex - FB
Belt Drive Question
Ray Chiappe
PostPosted: Thu Sep 06, 2012 12:12 pm    Post subject: Belt Drive Question Reply with quote
How long should a belt last, given it is not too tight or too loose?? Also is it a good idea to turn a belt around?? Im runnin a Rotax with a 16 driver.
Dominic Greco
PostPosted: Thu Sep 06, 2012 5:42 pm    Post subject: Reply with quote
Get with Nick Weil at:
http://www.speedquestkarting.com/
He is a road racer and Rotax dealer
www.southernkartclub.com
Chris Hegar
PostPosted: Fri Sep 07, 2012 9:11 am    Post subject: Reply with quote
We have had belts last for years but it all comes down to many factors. How much you run, motor HP, if you send rocks, gravel, dirt, rain water, ect through the drive system, how you maintain adjustment of the belt and how small of a gear you run. Big sprockets like a 19 tooth will be easier on it and small ones like the 14 will work it harder due to less tooth engagement. If you see teeth worn on the drive edge flip over the belt but expect you will need another fairly soon. I'd expect a belt on any tag motor to make it through a full season then change it just to be safe. That's our opinion. Wink
www.Hegar4.com
Ray Chiappe
PostPosted: Fri Sep 07, 2012 9:45 am    Post subject: Reply with quote
I was thinking that a 16th driver was small, but if I switch now, I'll have to buy a boat load of axle gears!! Thanks Chris
Jeff Wesell
Advertiser
Advertiser
PostPosted: Sat Sep 08, 2012 12:37 pm    Post subject: Reply with quote
I agree with Chris. I've been running belt drive with our Leopard setup for a few years now. Belts, if taken care of, will last a season if not even longer. We're in the minority in our class with the belt drive/chain drive choice, but even with the banter about the pros/cons of either, I am pleased with our choice.
Jeff Wesell
STREETER SUPER STANDS - Kart Stands and Pit & Trailer Accessories
Facebook
(262) 457-5018
Ray Chiappe
PostPosted: Sat Sep 08, 2012 8:17 pm    Post subject: Reply with quote
Jeff if you mind me asking, what drive gear do you run???
Jeff Wesell
Advertiser
Advertiser
PostPosted: Sun Sep 09, 2012 9:47 am    Post subject: Reply with quote
16 tooth is the normal drive sprocket we use for the majority of tracks we run. We do also have (if needed) 15 and 17 tooth drives.
Jeff Wesell
Facebook
(262) 457-5018
DB time: 0.184237 (60.19%), total time:0.306073, queries:38
