patrick slattery
Joined: 23 Apr 2004 Posts: 787 Location: United States, Ohio, cleves
Posted: Tue Sep 04, 2012 9:30 am Post subject: SSX Can Cleaning |
Any good tips on how to clean all the goo and rust out of this can?
Pat |
Joined: 19 Jul 2002 Posts: 4303 Location: United States, South Jerrrsey,
Posted: Tue Sep 04, 2012 11:11 am Post subject: |
Put it on the hibachi until it stops smoking then knock the ash out.
Yamaha KT100 Service Center
40 years karting experience |
Mark Erpelding
Joined: 27 Dec 2007 Posts: 138 Location: United States, Indiana, Ft Wayne
Posted: Wed Sep 05, 2012 2:14 pm Post subject: CAN CLEANING |
I sell commercial cleaning chems so I submerge it in our liquid oven cleaner. I usually let it set in it for about 4 hours. Then use a maroon 3m scratch pad on the outside. I heard if you put trans fluid on it, it will burn into it and keep from rusting. I have never used tranny fluid but I have used WD 40 and it doesn't seem to do much. The next time I clean it I am going to try trans fluid. _________________ We spend our money on Racing, Whiskey, and Women ~ The rest we waste! |
Dan Rudd
Posted: Sat Sep 08, 2012 2:22 pm Post subject: |
I cleaned ours in vinegar in my ultrasonic cleaner and then coated in trans fluid when clean. The trans fluid gives it a great appearance, it almost looks like gun bluing.
Dan |
Frankie Schaffier
Joined: 18 Jul 2001 Posts: 468 Location: United States, Ohio, Fostoria
Posted: Sat Sep 08, 2012 6:30 pm Post subject: |
WD40 won't work, as Mark said.
After you get the can/pipe clean. Coat it with trans fluid, then fire the kart and let it burn off. Then shut down the kart, wait a short bit then coat it again before the pipe cools. When you come in off the track, wipe it again with trans fluid while the pipe is still warm. After a few times, it'll look "blued" like Dan said. It also won't rust as easy, almost not at all. I'm not sure if the metal is sucking up the ATF, or if the burnt ATF is coating the pipe or whatever. But whatever it is, it works well. _________________ Frankie
Comet Eagle
Emmick Elite-Parilla TT25
Burris Racing www.burrisracing.com
Stoney Creek Motorsports |
