OTK - LB
Franklin / Merlin USA - FB
TAG Setup for Road Racing
Goto page Previous  1, 2
Clark Gaynor
PostPosted: Wed Sep 05, 2012 7:09 pm    Post subject: Reply with quote
By the way Bob, at Summit Main start with a 16:78 gear and take it from there. I assume you're running Stock Leopard?
Clark Sr.
Jim McMahon
PostPosted: Wed Sep 05, 2012 8:29 pm    Post subject: Reply with quote
Al your narrow approach works with karts that are very low powered. KT's and the like. For TaGs its a different story, they make almost double the power of the KT. A narrow setup with these is a great was to tune yourself to the rear on almost any road course, especially with a typical CIK/TAG chassis that is designed to work with a 140CM rear track.
Now if they run Daytona, all the way around a narrow track/hard tire approach would work, but that's about the only situation that it's going to help. Ie somewhere where cornering means next to nothing. For a lot of road courses with a KT thats probably the case, not so much with a TaG.
You also need to consider that karts are a LOT heavier these days.
John Kuntze
PostPosted: Thu Sep 06, 2012 11:39 am    Post subject: Reply with quote
The old theroy of narrow is faster died along time ago even in the KT100 classes. For a new guy start with sprint set up once you are use to it experiment with taking out a little bit of camber and caster if you want to see what happens some tracks you can some you can't.
John Kuntze
ekart99@aol.com
Peter Zambos
PostPosted: Thu Sep 06, 2012 1:55 pm    Post subject: Reply with quote
We followed the trend some years ago and moved from WKA sit up enduro with a KT100 to TAG. Without thinking of the consequences, we put a similar set up on our TAG kart. Took the key hole at Mid Ohio and it worked so poorly that it nearly stalled out the motor.
Bob Wimmer
PostPosted: Sun Sep 09, 2012 6:06 pm    Post subject: Reply with quote
Wide works for a TAG! Over a second a lap faster at Summit Point this weekend when running the rear track at 54 1/2 vs. 52 inches. Saw no appreciable loss of speed on the straights. Front track didn't seem to effect lap times nearly as much.
Wild Wimmer Racing
Animal Sprint & Enduro
Leopard Enduro
Page 2 of 2
DB time: 0.261002 (64.6%), total time:0.404012, queries:38
