Bob Wimmer
Joined: 21 Sep 2011 Posts: 25 Location: United States, Maryland, Gaithersburg
Posted: Tue Sep 04, 2012 9:08 am Post subject: TAG Setup for Road Racing |
I've got a Kosmic T7 32mm chassis and am looking for the caster, camber, toe and cross settings folks typically use for road racing. Not looking for exact numbers, but a general range.
Thanks _________________ Wild Wimmer Racing
Animal Sprint & Enduro
Leopard Enduro |
Jim McMahon
Joined: 07 Apr 2007 Posts: 2779 Location: United States, St. Paul,
Posted: Tue Sep 04, 2012 9:21 am Post subject: |
Start with your typical sprint setup. Tune from there. Honestly. It's going to depend on the specific track you are at anyway, surface composition etc etc. _________________ CES Grattan pre-entry is open. TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart.
Click Here to enter Grattan online |
Peter Zambos
Joined: 22 Jun 2006 Posts: 554 Location: United States, Illinois, near Chicago
Posted: Tue Sep 04, 2012 12:42 pm Post subject: |
| Agreed. There is very little difference between our sprint and road race set ups. |
al nunley
Posted: Tue Sep 04, 2012 9:25 pm Post subject: |
Your sprint setup will be good, as said, but I would change a few things.
A lot more air pressure in the tires.
As narrow as you can get.
Smaller, harder tires.
Anything you can do to improve the airo dynamics.
Maybe sounds strange, but it works. A big road race course will not have any turns anywhere near a sprint track. That, and the speeds on the strights, are the reasons for the setup. _________________ If the data does not support the theory, get a new theory. (Al Nunley)
Bob Wilson
Joined: 12 Sep 2003 Posts: 369 Location: United States, Washington, Spanaway
Posted: Wed Sep 05, 2012 7:01 am Post subject: |
| Jim McMahon wrote: | | Start with your typical sprint setup. Tune from there. Honestly. It's going to depend on the specific track you are at anyway, surface composition etc etc. |
Definitely a good sprint set-up. The narrow crap with the skinny tires doesn't work. Been there, done that. _________________ Bob Wilson
SPS Racing |
Clark Gaynor
Joined: 29 Aug 2002 Posts: 541 Location: United States, Pennsylvania,
Posted: Wed Sep 05, 2012 7:37 am Post subject: |
Agreed, go with your sprint set-up, other then the gear of course. DON'T do the narrow, skinny/hard tire thing!! As Bob Wilson said-- it doesn't work. The things draft so well, you're not going to get away from anybody on the straights, but you really need the thing to handle.
Just curious, are you coming to Summit Point this weekend? I just noticed you're from Maryland.
Clark Sr. |
Bob Wimmer
Posted: Wed Sep 05, 2012 10:41 am Post subject: |
That's the plan. The boys aren't racing, so it time for the old man to have some fun! _________________ Wild Wimmer Racing
Leopard Enduro |
joseph hollinger
Joined: 12 Sep 2002 Posts: 9532 Location: United States, California, san francisco
Posted: Wed Sep 05, 2012 12:01 pm Post subject: |
| al nunley wrote: | Your sprint setup will be good, as said, but I would change a few things.
Maybe sounds strange, but it works. A big road race course will not have any turns anywhere near a sprint track. That, and the speeds on the strights, are the reasons for the setup. |
If you follow this advice, you will finish last. Road racing setup is basically identical to sprint. Start with what you sprint with and adjust to suit the track. _________________ A lie gets halfway around the world before the truth has a chance to get its pants on. -- Winston Churchill. |
al nunley
Posted: Wed Sep 05, 2012 12:20 pm Post subject: |
Well, I’ve been there, done that too, and it did work quite well. Can't speak about you, just me.
But be safe, run what everybody else is running, you should be able to keep up with them that way. _________________ If the data does not support the theory, get a new theory. (Al Nunley)
joseph hollinger
Posted: Wed Sep 05, 2012 12:41 pm Post subject: |
| al nunley wrote: | | Well, I’ve been there, done that too, and it did work quite well. |
Al,
my understanding is that you tried this once and that that was decades ago. I've been road racing, first in TAG and now in shifters for about ten years and I'm still doing it. Everywhere from Willow Springs to Portland Oregon and Topeka Kansas. I know what the **** I am talking about. _________________ A lie gets halfway around the world before the truth has a chance to get its pants on. -- Winston Churchill. |
Bob Wilson
Posted: Wed Sep 05, 2012 2:07 pm Post subject: |
The narrow set-up data no longer supports your theory, it's time to embrace a new theory. _________________ Bob Wilson
SPS Racing |
Chris Hegar
Joined: 25 Jun 2002 Posts: 3537 Location: United States, Oregon, Portland
Posted: Wed Sep 05, 2012 2:47 pm Post subject: |
The narrow setup was the trick back in the time of 100cc piston port classes but the newer higher HP tag motor package combined with a wider Euro chassis, modern tire compound and side wall is now the ticket. Over the ages we have traded in narrow American produced karts that needed narrow and high pressure tire to build heat to what we see today in the evolution. In the 80's and 90's that is the way it was, remember the Emmick Top Gun situp chassis... that was the hot ticket on some sweet SL3 Dunlops.
I'd go wide sir, I like em wide.  _________________ www.Hegar4.com |
Bob Wimmer
Posted: Wed Sep 05, 2012 2:56 pm Post subject: |
With such little body work on a tag, I can't believe track width makes much of a difference. What about caster and camber? Do reducing those without compromising cornering speed help? And I know that a tight kart is a slow kart.
Leopard Enduro |
joseph hollinger
Posted: Wed Sep 05, 2012 3:12 pm Post subject: |
| Bob Wimmer wrote: | With such little body work on a tag, I can't believe track width makes much of a difference. What about caster and camber? Do reducing those without compromising cornering speed help? And I know that a tight kart is a slow kart.
Thanks |
I think most road racers use less caster than you'd see on a typical sprint setup. But it really depends on the specific track. I don't understand camber in a kart, so I'm not going to comment except to say that I run none to a little positive. _________________ A lie gets halfway around the world before the truth has a chance to get its pants on. -- Winston Churchill. |
Bob Wilson
Posted: Wed Sep 05, 2012 4:06 pm Post subject: |
Trust me, 55" inches on the rear, MG Yellows or equivalent compound of the manufacturer of your choice with a starting point of 11 pounds. The camber is your king pin inclination. More camber adds stabilization to your steering at high speeds. Less camber gives a quicker, more darty (I know that's not a real word) steering. We tried running our Rotax on the big tracks narrow and it was a true handful, almost un-drivable, in the corners. The wider we went, the faster we went. Sure enough, gearing was the only change we were making on the transition from a sprint race to a road race. Follow your gut, you have to drive it. Set it up how you want to drive it. This has worked for us. _________________ Bob Wilson
SPS Racing |
