Bondurant - LB
Brett King Design
Franklin / Merlin USA - FB
Rok TT Wiring
Craig Diller
PostPosted: Tue Aug 21, 2012 6:06 am    Post subject: Rok TT Wiring Reply with quote
I am having problem with a Rok TT I can not get it to run without the battery connected and I know it should stay running without a battery. Does any one have a wiring diagram.
Craig
William French
PostPosted: Thu Aug 23, 2012 12:15 pm    Post subject: TT wiring Reply with quote
I would image you are having a ground problem. I simply make my own wiring harness for my Rok TT's.
You could always just run a direct ground wire from your battery to the two points on the engine and test it. Simply unplug everything else and it shoud run fine using an external starter. Then if you want to take it a step furter you can fix up a kill swith and starter button. I use the Rotax ones. They work great.
DB time: 0.099851 (36.13%), total time:0.2764, queries:38
