Bondurant - LB
Top Kart USA - SS
KG Plastics - FB
spindle bearing removal
Ryan Leger
PostPosted: Sun Aug 19, 2012 9:09 am    Post subject: spindle bearing removal Reply with quote
i am running a ven99 front break setup and i want to change from a 8mm king pin to a 10mm kingoin but i cannot get the bearings out there 2 bearing on top and 2 on the bottom and they are stuborn as **** any help with any tips to get them out plz!
Tyson Henry
PostPosted: Sun Aug 19, 2012 12:16 pm    Post subject: Reply with quote
You have to get the spacer that is in the middle out of center just a bit so you can get an edge of the bottom bearings. Once an edge is showing, use a punch or screwdriver and hammer away.
DB time: 0.367621 (62.74%), total time:0.585899, queries:38
