Bondurant - LB
DRT Racing - FB
front spindle bearing
Ryan Leger
PostPosted: Sat Aug 18, 2012 8:57 pm    Post subject: front spindle bearing Reply with quote
Hey guya need aome help was wondering if anyone neq what aize bearing i would need for my front spindle its a crg ven99 front brake setup amd i want to comvert it to 10mm king pin but the spindlw is a 17mm amd the 10mm bearings out of my 25mm spindles wont fit from thw looks of it so was wondering id anyone new the bwaring size i would need
Joe Ricard
PostPosted: Sun Aug 19, 2012 10:13 am    Post subject: Reply with quote
17mm x 30mm
Arrow AX-8/ Rotax Sr.
Ryan Leger
PostPosted: Sun Aug 19, 2012 11:07 am    Post subject: Reply with quote
im talking about the bearing in the actual spindle they dont measure 17x30 mine were od 22mm id 8mm and height was 7mm could ai run a bearing with a 22x10x6 dimensions
Joe Ricard
PostPosted: Mon Aug 20, 2012 5:01 am    Post subject: Reply with quote
So you want a King Pin Bearing 8mm ID x 22mm OD All the kart shops carry them. it's also the same as a roller blade or skate board wheel bearing.
Ryan Leger
PostPosted: Mon Aug 20, 2012 5:47 am    Post subject: Reply with quote
Thats whats in it now im changing to a 10 mm king pin so im guessing i would need a bearing with same od and with a in of 10mm
DB time: 0.116907 (39.46%), total time:0.296247, queries:38
