larry brown 11
Posted: Fri Aug 17, 2012 8:25 am Post subject: Stolen vintage kart engine, Coleman starters |
Stolen karting equipment.....
August 3, 2012 these items were taken from my shop in Tucson, Az.
Vintage McCulloch 101B, custom one of a kind megaphone exhaust, all steel TIG welded, with a machined aluminum reverse cone attached with small roll pins. Chrome head shroud and fan shroud, but fan shroud painted yellow. Set up for HR series carb. Sloper intake manifold. Home built ignition side starter nut for LH starting. All new parts inside, .020 bore, fresh and run and run just one time.
Two Coleman gear reductions starters, one RH, one LH, with DEKA brand batteries. Set up with deep 5/8 sockets for external starting.
Any info leading to the recovery will be appreciated. Will consider a modest reward, particularly for engine recovery.
THANK YOU FOR HELP |
Kent Metcalf
Joined: 29 Sep 2009 Posts: 174 Location: United States, Missouri, fenton
Posted: Tue Sep 04, 2012 9:12 pm Post subject: |
there is a vintage kart race / show going on in West Quincy IL. at TNT Kart Track http://www.tntkartways.com/ coming up next weekend Sept. 7/8/9 you might want to go there and walk around or give the track owner a call and send him a photo. Just a heads up. Good luck _________________ St. louis Mo. |
