Ribtect - SS (non-flash)
Honda Det Counter
Larry Dobbs
PostPosted: Tue Aug 14, 2012 4:21 pm    Post subject: Honda Det Counter Reply with quote
I would like to buy a Honda Det Counter to be used on my Rotax 257. If someone has it with LED’s (a la Sam Zavaglia) that would be even better! Please contact me at larrydobbs@hotmail.com
Larry Dobbs
Matthew Walker
PostPosted: Tue Aug 14, 2012 9:58 pm    Post subject: Reply with quote
Hi Larry,
Here's a link to Sammy's website. You can contact hime off there. I believe he can supply det counter and lights complete or just lights if you want to source your own counter and has paypal Smile
Some of the other stuff he is doing with Michron is awesome - electronic power jet cutoff via shift lights etc. He is truly the master of billykart electronics!
good luck
Matt...
http://www.samzavaglia.com/Electronics.htm
Experience is that marvelous thing that lets you recognise a mistake when you make it again!
PostPosted: Wed Aug 15, 2012 3:59 am    Post subject: Reply with quote
Has anybody tried April Systems Det counters?
http://www.aprilsystems.co.uk/product/parts.htm
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Francis PAYART
PostPosted: Wed Aug 15, 2012 12:59 pm    Post subject: Reply with quote
Hello,
We use it for a year now successfully. Laughing
We have choosen M6 stud for twin cylinder without counter.
The advantage is that the sensors are connected to AIM.
Reliable, easy to integrate and to adjust the sensitivity.
Francis
PostPosted: Wed Aug 15, 2012 3:57 pm    Post subject: Reply with quote
I was thinking of using one on the dyno for building ignition curves...
CR
Allan Litten
PostPosted: Wed Aug 15, 2012 4:32 pm    Post subject: Det Counter Reply with quote
I have used the April detonation sensors, both the 8mm on the cylinder base and 6mm on the head and found them to give a good indication of detonation.
As Francis said, the sensitivity is adjustable and that is a good thing with a little knowledge.
The only thing I don’t like about them is the way the connector comes off the top of the nut. I suggest you put them on the base of cylinder to avoid damaging/hitting the connector with your arm and also avoid EMI from spark lead.
Regards
Allan
DB time: 0.128152 (53.27%), total time:0.240574, queries:38
