Ruben Tarca
Posted: Tue Aug 14, 2012 9:02 am Post subject: TopKart handling |
I'm running Yamaha super can and the chassis works just fine at each cornner except a 45 degree sharp right hand turn.
Tried different set ups (with out loosing the other corners) and nothing seems to work, still I loose my rear end every time.
Do you guys have any suggestion?
As always I appreciate your advise
Thanks |
Ihor Bilyy
Joined: 13 Jul 2005 Posts: 536 Location: United States, Georgia, Canton
Posted: Wed Aug 15, 2012 7:38 am Post subject: |
| Something is not correct. Hard to imagine 45 degree sharp turn. maybe you meant 135 degree. |
Posted: Wed Aug 15, 2012 8:23 am Post subject: |
Complete with rubbered-in racing line
If it's only one corner, you might want to look at your driving or your line through the corner. Are you turning too abruptly/charging the corner too hard? On a tight corner though, any faults in your chassis setup will come to the surface though, since you're going to be loading and working the chassis quite hard in a tight corner.
Is it loose on entry, apex, or exit? That'll determine what you change, if anything. _________________ T.J. Koyen
www.oktanevisual.com
Exprit/Leopard |
Ihor Bilyy
Posted: Wed Aug 15, 2012 8:36 am Post subject: |
Oh, what is 180 degree turn than?
The turn Ruben is talking about is kind of hairpin but over the hill, where the highest point right in the middle. It is also the only right turn on a track. |
Posted: Wed Aug 15, 2012 10:30 am Post subject: |
| Ihor Bilyy wrote: | Oh, what is 180 degree turn than?
180 is a complete hairpin, like a U. I understand how it could be confusing because you're measuring the turns differently. I don't know, that's just how I've always referred to them, even if the measurement is inconsistent.
If you are cresting a hill as you hit apex, the kart will get light and break free. _________________ T.J. Koyen
Exprit/Leopard |
Ruben Tarca
Posted: Wed Aug 15, 2012 10:41 am Post subject: chassis and handling |
TJ,
thanks for your response.
The problem is at entry
(And yes the turn is 45 degrees as your sketch) |
Oscar Biondi
Joined: 27 Sep 2011 Posts: 221 Location: United States, California, Carmichael
Posted: Wed Aug 15, 2012 11:23 am Post subject: |
| TJ Koyen wrote: | | Ihor Bilyy wrote: | Oh, what is 180 degree turn than?
If you are cresting a hill as you hit apex, the kart will get light and break free. |
Why would the angles be measured differently? Turns are measured as they deviate from a straight line, without changing the driving direction. Ihor is right, that should be a 135 degree turn. Otherwise, what would a 45 degree turn, measured from the straight line, be called in degrees? |
Ihor Bilyy
Posted: Wed Aug 15, 2012 11:30 am Post subject: |
| Yeah, it is more degree the more you turn. If you not turning, its is close to 0 or straight. We are not in geometry class. |
Posted: Wed Aug 15, 2012 4:04 pm Post subject: |
Guys, all I'm saying is I consider it a 45 degree turn too. And to me a 180 is a hairpin. That's just how it's always been in my mind. I realize it's actually a 135 degree turn, but this is all semantics. None of this matters.
Ruben,
I'd first look at what axle you have in the rear and consider going to a softer axle or at least softening the rear up if you can. If you have too stiff of an axle, it will react very quickly, causing the kart to abruptly lift the inside rear and give you oversteer almost as soon as you turn the wheel.
Also try narrowing the front up in 5mm increments if you still need to get rid of more oversteer. _________________ T.J. Koyen
Exprit/Leopard |
Mike Goebel
Posted: Wed Aug 15, 2012 5:38 pm Post subject: |
Turns shall be determined by the included angle from this point on.
mfg Technology Centre
Oscar Biondi
Posted: Wed Aug 15, 2012 6:03 pm Post subject: |
| Mike Goebel wrote: | Turns shall be determined by the included angle from this point on.
Mike G. |
So a 180 degree turn is just a straight? And what we think of a 180 turn would be a 0 degree turn? it's all semantics I guess |
Posted: Wed Aug 15, 2012 6:31 pm Post subject: |
I measure turns by how much they hurt my ribs. _________________ T.J. Koyen
Exprit/Leopard |
Mike Goebel
Posted: Wed Aug 15, 2012 9:16 pm Post subject: |
| Oscar Biondi wrote: | | Mike Goebel wrote: | Turns shall be determined by the included angle from this point on.
Mike G. |
There is no included angle in a straight
gregg boyce
Joined: 27 Jul 2004 Posts: 1143 Location: United States, Tennessee, nashville
Posted: Sat Aug 18, 2012 8:04 am Post subject: |
Mike G,
There is if you're michael Schumacher!!
Gb _________________ My imaginary friend says your crazy. |
Greg Wright
Joined: 25 Oct 2001 Posts: 2499 Location: United States, Indiana, Clermont
Posted: Sat Aug 18, 2012 9:49 am Post subject: |
Just semantics, I agree however I"ve never heard of terming corners this way. Is a 90 degree turn actually 0 degrees?
No big deal, just seems odd to me. _________________ Greg Wright
Rapid Racing Inc.
I AM INDY!!
"When in doubt, gas it. It won't help but it ends the suspense." |
