Bondurant - LB
Tony Kart/Vortex - FB
FJ / World Formula Rule Changes
Goto page 1, 2, 3  Next
Eric Nelson
PostPosted: Fri Aug 10, 2012 6:24 pm    Post subject: FJ / World Formula Rule Changes Reply with quote
Does anybody know why we are suddenly required to run the electric starter on the World Formula engine?
The latest SCCA Rules say the World Formula must be run "As Homologated." However, checking the CIK-FIA website, the World Formula doesn't appear to be a homologated engine. Search the word "Briggs" on the CIK-FIA website, nothing relevant even comes up.
I believe the WKA dropped the electric starter requirement back in 2006, and I know for certain the IKF did. For years people have been throwing the starters away, to the point where very few used engines still have the starters with them. I have several customers asking what happened, suddenly they have to spend over $100 to retrofit a non-performance part on motors they've been using in SCCA for years.
Scott Boito
PostPosted: Fri Aug 10, 2012 7:55 pm    Post subject: Reply with quote
Where do you see that this is a change? Looks like no change to the WF over the last few years at least (other than the weights and slide restrictor).
KM #68 - Haase/Honda kart
BetterOffRacing
Member of the SCCA KAC
Eric Nelson
PostPosted: Sat Aug 11, 2012 7:59 am    Post subject: Reply with quote
I agree. A customer brought me the "As Homologated" portion of the newest SCCA rule. I explained what a karting "Homologation" is and that the WF doesn't have one, but he was still understandably concerned. So the question was posed to the KAC this past Thursday, and the answer came back "Yes, starter is required." No explanation available.
I can't see any SCCA language that specifically addresses the electric starter. There is no "Homologation" as the term is typically used in karting, from 2005 through last month we've been running off of IKF / WKA club rules. Nothing performance-oriented has changed in World Formula since early 2007, it's a very stable rules package, which is why is was chosen for FJ. Why mess with it now?
Eric Clements
PostPosted: Thu Aug 16, 2012 8:48 pm    Post subject: Reply with quote
The book should probably say "as delivered".
The Solo rules are a list of allowances, not a list of limits. If it doesn't say you can, you can't.
The WF is delivered with a starter. If you want to remove the starter you need to find the line in the rulebook that says you can.
Eric Nelson
PostPosted: Fri Aug 17, 2012 10:18 am    Post subject: Reply with quote
I understand. But that type of rule implementation can really lead to confusion when there is no thorough "Technical Manual." For instance, I see lots of painted WF engine covers in SCCA, blue and other colors. Virtually all engines using some piece of non-original hardware. "Blueprinted" engines that are bored and decked. Even the clutch, the diagram that comes with it new is incorrect, so it has to be installed backward from what's shown in order to work right. All technically not allowed, but a majority of people will show up and run that way regardless. Where to draw the line?
Again not trying to be contrary, just pointing out, it can get confusing. It happened with the Raptor, SCCA book says it has to be "Stock" which means 5 HP. But "Stock" to a kart engine builder means IKF or WKA "Stock Class" rules, very different, can be built to 8 - 10 HP.
Larry MacLeod
PostPosted: Sun Aug 19, 2012 4:43 pm    Post subject: Reply with quote
The question is, are solo people pulling the starters off? I know some aren't running batteries, but the BWFs I've seen still have the starters hanging off the engine.
Just because some road racers are doing it doesn't mean its happening in the solo community. Just sayin'.
Larry
Dad of a Solo Jr
F125 #196
Lefty Funk
Detroit Region
Eric Clements
PostPosted: Sun Aug 19, 2012 6:43 pm    Post subject: Reply with quote
Yes, Solo people are running without starters. Having been youth steward for dozens of west coast national events I can't remember a season that someone didn't up without a starter.
Brian Regganie
PostPosted: Sun Aug 19, 2012 7:07 pm    Post subject: Reply with quote
I'm all for adding a line in the rulebook that states that the starter can be removed. But as for now it doesn't. As stated before, The WF is delivered with a starter. If you want to remove the starter you need to find the line in the rulebook that says you can.
Personally I hope this is a rule that is adopted for next year. As for 2012 I think the rule is clear, the starter must be installed.
Joe Ricard
PostPosted: Mon Aug 20, 2012 5:05 am    Post subject: Reply with quote
I would like to see the statement read World Formula Starter and battery must be functional and be operated by the driver in grid.
It's really one of the benefits of the WF and Mini Max the engines can be re-started on course by the driver if it stalls.
Keeps the workers from going out and dragging them of course and delaying the event.
Arrow AX-8/ Rotax Sr.
Eric Nelson
PostPosted: Mon Aug 20, 2012 7:34 am    Post subject: Reply with quote
Got it. So no painted engine covers or reversed clutches either, right?
Joe Ricard
PostPosted: Mon Aug 20, 2012 12:38 pm    Post subject: Reply with quote
Depends Eric,
Do you want this to be another one of those classes that requires one to out spend your competition?
Thought I read somewhere that Junior B and A are places to start youngin's in Autocross.
Leave the motor alone (spec) and learn to drive and tune the chassis.
If Briggs had a sealed motor program for WF like the LO206 I would be right behind it all the way.
Eric Nelson
PostPosted: Mon Aug 20, 2012 1:14 pm    Post subject: Reply with quote
Outspend? Where did I say that? I'm asking about spray paint.
I'm not trying to cause a problem... I have customers who are asking me these things. The motors they ran last year are now being called illegal. And truthfully I have no idea where to get clear answers on this stuff at this point.
I'm not concerned with the content of the rule, I can follow anything and pass the info on to customers, as long as it's clear. All I'm trying to accomplish here is prevent somebody blaming me for their DQ, when what they have is the same equipment that was legal until two months ago.
Unfortunately the rule is not written thoroughly enough. Taken literally, you can't even add oil or adjust the valves.
Brian Regganie
PostPosted: Mon Aug 20, 2012 1:37 pm    Post subject: Reply with quote
It was never legal. If your customer was running the motor without the starter 2 months ago they were illegal. Apparently no one noticed, cared to comment, or read the rule book.
Eric Nelson
PostPosted: Mon Aug 20, 2012 2:00 pm    Post subject: Reply with quote
Well, not really. The rules last year referred to a non-existent homologation, just as they do now. Previously this was interpreted (by the SCCA, not me) to mean that IKF / WKA -legal motors were allowed. Now it's being interpreted differently.
Larry MacLeod
PostPosted: Mon Aug 20, 2012 7:54 pm    Post subject: Reply with quote
Another reason I'm glad we own a Yamaha. Less bickering over rules.
Larry
F125 #196
Lefty Funk
Detroit Region
Page 1 of 3
DB time: 0.292461 (54.58%), total time:0.535838, queries:38
