Michael Boone
Joined: 31 Jan 2007 Posts: 1184 Location: France, Not USA state, Nantes
Posted: Wed Aug 15, 2012 11:06 am Post subject: |
Carlos it leaves a nice shinny coating on my KZ pipe!
MB
You know what they say about opinions!  _________________ If you can't keep up don't worry I'll be coming around again !
KZ 125 Masters
FFSA National race Director
http://www.ask-ancenis.fr/ |
R Anthony Hutchinson
Posted: Thu Aug 16, 2012 8:07 am Post subject: |
CLARIFICATION: While our painted pipe was legal for the club and the regionals, I have since found out that it is NOT legal for the upcoming Canadian Championships based on the following Rotax Max rules:
9. ANYTHING WHICH IS NOT EXPRESSILY ALLOWED IN TECHNICAL REGULATIONS IS FORBIDDEN.
20.1 Must be supplied by BRP-POWERTRAIN and cannot be modified except for the replacement of the silencer absorption material and the use of threaded fasteners in place of the rivets for securing the silencer end cap.
Be forewarned!! |
Ryan Leger
Posted: Thu Aug 16, 2012 8:48 am Post subject: |
| thanks anthony im a fellow canadian racer , and this is what i was trying to figure out if it was legal for nationals or not club racing i dont think there going to be to picky about it at 3s and goodwood and such but i figured in the EKC they may have a problem with it |
Posted: Thu Aug 16, 2012 9:00 am Post subject: |
| Ryan Leger wrote: | | thanks anthony im a fellow canadian racer , and this is what i was trying to figure out if it was legal for nationals or not club racing i dont think there going to be to picky about it at 3s and goodwood and such but i figured in the EKC they may have a problem with it |
No problem. And just so you know, that was directly from Brian Campbell himself. (He's handling the Nationals). |
Posted: Mon Aug 27, 2012 4:30 pm Post subject: |
Painting is not a modification it was painted when manufactured so it's nothing more than maintenance it has no effect on performance a little common sense needs to be applied here.
If you de grease and sand it down to remove any loose coating a good flat black header paint will make a nice job. They must be cured by heating and cooling after aplication.
Brian |
al nunley
Posted: Tue Aug 28, 2012 7:05 am Post subject: |
| Brian Degulis wrote: | Painting is not a modification it was painted when manufactured so it's nothing more than maintenance it has no effect on performance a little common sense needs to be applied here.
Brian |
I designed and built pipes for something like 20 years. Are you saying I don't know what I'm talking about?
Anything that effects the tempurature in the pipe is going to effect it's performance. _________________ If the data does not support the theory, get a new theory. (Al Nunley)
Posted: Tue Aug 28, 2012 9:09 am Post subject: |
| al nunley wrote: | | Brian Degulis wrote: | Painting is not a modification it was painted when manufactured so it's nothing more than maintenance it has no effect on performance a little common sense needs to be applied here.
Brian |
Anything that effects the tempurature in the pipe is going to effect it's performance. |
The topic of this thread isn't wether or not you know what your talking about. If it were I wouldn't comment because I don't know you and wouldn't have any way of knowing the extent of your knowledge. Getting back to the topic I can well understand how a ceramic coating or heat blanket might effect performance. I don't believe that a thin layer of paint would. For the moment lets assume your correct in thinking that even a thin layer of paint has an effect on performance. If that's the case and the system was painted when manufactured and that original paint is now deteriorating then wouldn't the system have to be re painted to operate at the original spec and performance level?
Again I don't think it means a thing and I can't see how anyone would ever know it was re painted unless it was done with some kind of insulting coating. My opinion is based only on logic and I make no claims to have any expertise on the subject.
Brian |
Bob Rodrick
Joined: 07 Jun 2011 Posts: 37 Location: United States, Colorado, Edwards
Posted: Tue Aug 28, 2012 12:38 pm Post subject: |
| I believe from what I've read in the rules that painting the pipe is illegal. Maybe its a way of hiding modifications to the pipe???????? |
Mike Sirochman
Joined: 05 May 2011 Posts: 35 Location: United States, Florida, Crystal River
Posted: Fri Sep 21, 2012 11:44 am Post subject: |
This worked pretty good with trailer frames. Ospho. Take a read and give it a try.
http://www.ospho.com/directions.htm _________________ 2010 CRG Dark Rider DD2
Good judgement comes from experience. Experience comes from bad judgement. |
