Bondurant - LB
MRP - SS
KG Plastics - FB
Clearance on Clutch drum
Jeff Payne
PostPosted: Tue Sep 03, 2002 5:21 am    Post subject: Clearance on Clutch drum Reply with quote
How much clearance should I have between my clutch drum and the hex nut that holds it on? I have the 11 tooth sprocket with the stock thrust washer, seems a little too loose.
Nick Weil
PostPosted: Tue Sep 03, 2002 6:37 am    Post subject: Clearance on Clutch drum Reply with quote
Jeff,
There is a specific washer to use with the 11T setup. Check out this link and you will notice there is a 12t-16T washer and an 11T washer. The stock thrust washer you have would be from a 13T sprocket as most motors are shipped with 13T on them.
Clutch parts
Nick Weil
SpeedQuest
[ September 03, 2002: Message edited by: Nick Weil ]
Jeff Payne
PostPosted: Tue Sep 03, 2002 6:45 am    Post subject: Clearance on Clutch drum Reply with quote
Thanks for that link, great site.
DB time: 0.253485 (66.98%), total time:0.378475, queries:37
