Ocala Gran Prix - LB
Ribtect - SS (non-flash)
Leading Edge Motorsports
KT100 clutch removal
pat mccartin
PostPosted: Sun Jul 29, 2012 9:06 am    Post subject: KT100 clutch removal Reply with quote
how do you lock the crank to remove the starter / clutch nut?
pat mccartin
PostPosted: Sun Jul 29, 2012 10:07 am    Post subject: Reply with quote
disregard. Rope in the cylinder worked
Frankie Schaffier
PostPosted: Sun Jul 29, 2012 12:36 pm    Post subject: Reply with quote
Piece of fuel line works good also, may be just a bit easier to feed through the spark plug hole.
Frankie
Comet Eagle
Emmick Elite-Parilla TT25
Burris Racing www.burrisracing.com
Stoney Creek Motorsports
Joe Brizzolara
PostPosted: Sun Jul 29, 2012 6:44 pm    Post subject: Reply with quote
Pick up a piston stop. Can get one for less than $10 from Acceleration karting or others rather than taking a chance of putting something in your cylinder that may break off, melt or leave debris.
One of those little tools to have in your tool box.
patrick slattery
PostPosted: Sun Jul 29, 2012 6:56 pm    Post subject: Reply with quote
I was always told not to use piston stops, but does any one know any better?
Steve O'Hara
PostPosted: Sun Jul 29, 2012 11:05 pm    Post subject: crank holding Reply with quote
Ideally you don't want to use any kind of piston stop. The best way is to use the proper tool to hold the clutch or the rotor so the resistance to turning is directly at the point where the torque will be applied. Every clutch manufacturer makes a specific wrench to hold the clutch hub and there is also a tool to hold the rotor on the ignition side.
Horstman has a whole bunch of different clutch wrenches for the different models and L&T has a special tool as well.
If you don't have the correct tool use a pnuematic tool to remove and just let compression be the resistance to the turning of the crank.... works 99% of the time.
Steve O'Hara
Frankie Schaffier
PostPosted: Mon Jul 30, 2012 5:23 am    Post subject: Reply with quote
Your correct Steve, I don't disagree.
Frankie
Comet Eagle
PostPosted: Mon Jul 30, 2012 8:22 am    Post subject: Reply with quote
You have to take the clutch cover off then use a clutch wrench and a clutch puller for your particular clutch because, after you get the nut off it's still locked on the shaft taper.
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
pat mccartin
PostPosted: Mon Jul 30, 2012 10:57 am    Post subject: Reply with quote
Gif Cool
I removed a Hortsman wet clutch.
After locking the piston with rope. The nut came loose easily. Then I used a 3 jaw puller to slide the complete clutch assy off the crank snout.
DB time: 0.13989 (42.33%), total time:0.330443, queries:38
