Matt Clark
Joined: 26 Apr 2005 Posts: 175 Location: United States, Florida, Tampa
Posted: Thu Jul 26, 2012 8:41 am Post subject: Birel Freeline wheels on a Tony Kart |
Hey guys, trying to pick up a cheap set of decent mag wheels for my TK Krypton and have come across some Freelines for a good deal. Is there anything that I should be aware of as far as differences between these and the standard wheels that are on the kart? Are offsets the same? If not, is there a place I can find out the offset of them? Thanks.
Matt |
Ryon Beachner Advertiser
Posted: Thu Jul 26, 2012 3:18 pm Post subject: |
Matt,
Offsets are not the same. Try and stick with the OTK wheels for best performance, MXC's if possible.
However if you aren't at a point where you think you could tell the difference in handling, don't worry about it. It's always nice to have a second set of wheels on race day so you don't have to dismount practice tires. _________________ 2Wild Karting
www.2wildkarting.com
Shop: (949) 206-9906 |
Matt Clark
Posted: Thu Jul 26, 2012 4:06 pm Post subject: |
Ryon,
I'd say I'm far from a point of noticing, I'm 2 practice days in ha. So you think the difference would be negligible for someone like me? It's between either those or some aluminum douglas wheels which come with rain tires (which came off a TK). |
Posted: Thu Jul 26, 2012 5:11 pm Post subject: |
| Matt Clark wrote: | Ryon,
Tuning with different wheels is something people typically do after trying a whole host of other minor things. So, I would say if you absolutely need a second set, then its not a big deal, however the kart will perform better with the OTK's.
I would however avoid the aluminum wheels with rain tires as rain tires use a 180mm rear wheel instead of the 210mm rear wheel standard slicks take. So if you were to buy those, you would most likely be stuck with 2 useless wheels, unless it rains. _________________ 2Wild Karting
Mick Gabriel
Posted: Mon Jul 30, 2012 12:55 pm Post subject: |
| There's also nothing wrong with using the standard MXP wheel on the tonykart, we actually find it more consistant than the MXC. If you race mostly club buy a set of mxps and start off there, no real point in running the mxc's on a track without a ton of rubber. |
Rich Hays
Joined: 09 Sep 2005 Posts: 239 Location: United States, California, Huntington Beach
Posted: Wed Aug 01, 2012 9:54 am Post subject: |
The Freeline front wheels have the same offset as the OTK wheels (within a millmeter) The rear Freeline wheels have less offset by about 6-7mm I think. I can't quite remember the exact measurement but do recall that when putting the freelines on the rear, I had to widen the track by about half an inch total to match the track width with the OTK wheels.
-rh |
Chris Livengood
Joined: 24 Jul 2001 Posts: 2432 Location: United States, Pennsylvania, Da Burgh
Posted: Tue Aug 07, 2012 7:20 am Post subject: |
For 99% of the karting community wheels that are round and hold air are absolutely suitable. Though, consistent offset is a nice feature.
If you can find a deal on a set of wheels that meet this criteria, i'd say go for it. Then again, I don't sell wheels for a living so what do I know? _________________ http://www.Chrislivengood.net
http://www.Work-Racing.com
http://www.OurZeal.com
http://www.Karting101.com
"Auto racing, helping white guys get laid since 1887!!!" |
Matt Clark
Posted: Wed Aug 08, 2012 5:22 am Post subject: |
Thanks guys, ended up buying the freelines. Good thing too, as this past Saturday I forgot to check wheel lug tightness between runs and my left rear came lose and made the holes in my OTK wheel a little oblong That's a mistake I won't make again... |
