OTK - LB
Russell Karting - SS
SCCA Enterprises - FB
maranello rs7 brake help
Ryan Leger
PostPosted: Tue Jul 24, 2012 12:30 pm    Post subject: maranello rs7 brake help Reply with quote
Hey guys I have a maranello rs7 I'm running rotax its a 2007 chassis I belive what I want to do was put front brakes on it does anyone who exactly what parts I will need and what other kart parts will fit I heard parts from crg karts will fit but would like and experts help or someone who has done this before
Chris Rock
PostPosted: Thu Jul 26, 2012 11:32 am    Post subject: Reply with quote
Ryan,
Yes the Maranello brakes are the same as CRG. You will need a complete front brake set up including: master cylinder, calipers, rotors w/ carrier, front hubs. I would suggest matching your current version rear brake (ven99, ven04, ven05 etc). Depending on the version, some use the same spindle as the non-front brake version, some use different tapered spindle.
Ryan Leger
PostPosted: Thu Jul 26, 2012 12:56 pm    Post subject: Reply with quote
im running the ven05 i think on the rear it looks exactly the same as the ven05 on the crg so im guessing thats what it is , and what are you talking about with the spindles soryr still new to karting and learning
Chris Rock
PostPosted: Fri Jul 27, 2012 8:00 am    Post subject: Reply with quote
The front brake disc hub on the ven05 KZ(shifter) brakes has two different size bearings because the stub axle on the spindles has a larger diameter on the inside then the outside. You might have to also change spindles if you convert via a KZ setup. I think CRG also makes a brake disc hub that has 25mm bearings on both ends but I'm not positive on that.
Ryan Leger
PostPosted: Fri Jul 27, 2012 1:05 pm    Post subject: Reply with quote
Well right now I have 25mm maranello spindles on it is there anything I can do to make those spindle work and suggestions
Peter Zambos
PostPosted: Fri Jul 27, 2012 4:13 pm    Post subject: Reply with quote
You'd have to find a fabricator, as spindles for karts without front brakes...
don't have the bracket needed to attach the caliper
Even then, you'd have to make sure that the should of stub axle is in the same place or create a custom spacer to that your hub carriers are in the correct position. Frankly, all in all, for time, money and peace of mind, you're better off just getting the spindles made for front brakes.
DB time: 0.104993 (9.51%), total time:1.104348, queries:38
