Dan Pingston
Joined: 28 Jul 2010 Posts: 64 Location: United States, Florida, Jacksonville
Posted: Wed Jul 18, 2012 5:01 am Post subject: Exhaust Mount Recommendations |
I am getting ready to make the switch to Rotax and was looking around at exhaust mounts. Now if my theory of "you get what you pay for" holds true this Odenthal mount would be junk at $61.00 compared to the ProSpeed mount at $119.00, but in my past experience with other Odenthal products, they seem to be pretty nice. Another reason for looking at it is I am going to be getting a new kart soon too, and the Odenthal mount adjusts from 28mm frame rails up to 32mm, whereas the ProSpeed does not. I guess my question really is, has anyone ever used the Odenthal and is it any good?
http://www.accelerationkarting.com/odenthalrotaxexhaustmount.aspx
http://www.accelerationkarting.com/rotaxpipemountkit.aspx
Dan |
William French
Joined: 25 Mar 2008 Posts: 400 Location: United States, Michigan, Motor City
Eric Alexander
Joined: 19 Jun 2011 Posts: 126 Location: United States, North Carolina, Mooresville Motorplex
Posted: Wed Jul 18, 2012 8:28 am Post subject: |
I use the Odenthal mount ($61.00) and its fine. I did replace the stock bolts attaching the actual exhaust to the mount for longer ones. This allowed me to fit it more loosely than the stock bolts allowed - so it doesn't bind the chassis. But the mount is flexible and allows easy chain adjustments when set-up loose. However, don't forget the blue thread locker and/or safety wire on all the bolts.  |
Dan Pingston
Posted: Wed Jul 18, 2012 8:58 am Post subject: |
| Thanks guys. |
Dan Pingston
Posted: Wed Jul 18, 2012 3:46 pm Post subject: |
| So my local Rotax shop recommended that I use the ProSpeed mount. I have a blended frame that I am using for just a couple more races and it actually has 28mm frame rails at the engine. I am going to be moving to an EVRR soon, but I need to use the current kart for a few more races. Has anyone ever used the 30/92 mount on a 28mm frame? The 30/92 is the smallest that Prospeed makes. I figured maybe I could just wrap some electrical tape around the frame rails to give the mount something to clamp to. Suggestions/recommendations? |
Rich Hays
Joined: 09 Sep 2005 Posts: 243 Location: United States, California, Huntington Beach
Posted: Wed Jul 18, 2012 3:49 pm Post subject: |
I have used a 32/92 Prospeed mount on both the 30 and 28mm frame karts with no problems Just use the appropriate bottom clamp and all works well.
-rh |
Dan Pingston
Posted: Wed Jul 18, 2012 4:02 pm Post subject: |
| Would one of my spare engine mount bottom clamps work on it? |
Rich Hays
Posted: Thu Jul 19, 2012 7:31 am Post subject: |
That is what I used.
-rh |
Mike Zamora
Posted: Thu Jul 19, 2012 7:32 am Post subject: |
| If you are moving to an EVRR you might want to look into the OTK Rotax pipe mounts. Very nice.... |
Dan Pingston
Posted: Thu Jul 19, 2012 8:02 am Post subject: |
| Thanks Mike, but for the first 3 or 4 races with the Rotax I am going to be using my weirdo, "custom" Margay. I was hoping to get a mount that I could carry over to the new kart so I don't have to buy multiple mounts. The shop I am dealing with sells both Rotax and Tony Kart and they recommended using the ProSpeed mount. |
Roger Hargens
Joined: 25 Jan 2002 Posts: 444 Location: United States, Massachusetts,
Posted: Thu Jul 19, 2012 10:57 am Post subject: |
Dan - Rich is correct re: using the 32-92 clamp on a 28 or 30mm frame. It works on all three tube diameters. The 32-90 clamp (for CRG built karts) works on 28 and 30mm (CRG spaced) frames as well. The top bar is universal, for use on all frame sizes.
We sell Arrow, Tony and Margay karts and always install our pipe mounts on them w/ Rotax engines. _________________ Roger S. Hargens
www.prospeedkartsports.com |
Brent Harper
Joined: 30 Mar 2003 Posts: 892 Location: United States, Texas, Lubbock
Posted: Thu Jul 19, 2012 8:10 pm Post subject: |
Best Rmax mount I have found is the OTK style where the brackets mount to the outside of the bearing hangers. _________________ SWISS HUTLESS SWISS I/CMC ROTAX |
Ihor Bilyy
Joined: 13 Jul 2005 Posts: 538 Location: United States, Georgia, Canton
Eric Alexander
Posted: Tue Sep 04, 2012 6:02 pm Post subject: |
Just wanted to throw in a pic of the Odenthal Rotax exhaust mounts mentioned in the original post. Just as a reference for anyone searching this subject in the future.
