Bondurant - LB
Brett King Design
KG Plastics - FB
Rotax runs HOT!!
Jim Marks
PostPosted: Wed Aug 07, 2002 9:38 pm    Post subject: Rotax runs HOT!! Reply with quote
For the first 4 months I owned my Rotax I was blessed by how cool it ran. I found myself duct taping the radiator most of the time. Now it seems to be running very hot. At Willow, yesterday, in 95 degree heat, I could barely get 4-5 laps in before it climbed over the 80 degree celsius mark. I have done everything I can think of besides cracking the motor. Any ideas, please help!
Nick Weil
PostPosted: Thu Aug 08, 2002 12:08 am    Post subject: Rotax runs HOT!! Reply with quote
Are you sure it was over 80 celsius? That would be well over 200 Fahrenheit. If indeed that is the real deal, I would double check your fluid level obviously, and then possibly take of the cover and see what condition your gears are in. This can be done without breaking the seal.
Nick
Jeff Fontenot
PostPosted: Thu Aug 08, 2002 6:21 am    Post subject: Rotax runs HOT!! Reply with quote
What exactly have you done to reduce the temperature?
Are you running the correct Jet?
Change out your temperature gauge, maybe it is reading high.
Jeff
John Borroel
PostPosted: Thu Aug 08, 2002 7:12 pm    Post subject: Rotax runs HOT!! Reply with quote
I ran my first race a couple of weeks ago, I also had an overheating problem. It was at Amago Air Temp about 95'F by the end of the main my temp climed up to 176'F. Checked water level it was fine. Can jetting change the temp that much? It ran fast, but it could have been on the lean side. Its hard to get a good plug reading when you have a slow cool down lap.
John
Jeff Fontenot
PostPosted: Fri Aug 09, 2002 5:11 am    Post subject: Rotax runs HOT!! Reply with quote
Jetting can change the temp. How Much I do not know, but that is a factor.
Do not slow down on your cool off lap, keep the RPMs up and shut the motor off, before you get in the pits(when the RPMs are high) and coast in the pits. you will get a good plug reading then.
Nick Weil
PostPosted: Fri Aug 09, 2002 12:05 pm    Post subject: Rotax runs HOT!! Reply with quote
As a note to everyone on temperature. The Rotax Owner's manual states the normal operating range at 45 - 80 degrees Celsius.
For the Celsius-impaired this is:
113 degrees Fahrenheit - 176 degrees Fahrenheit
And just so you all know, it is possible to 'stick' the motor if you don't let it warm up to 113 Fahrenheit before really romping on it. Be careful and watch those temperatures...
Nick
Gary Kannegiesser
PostPosted: Mon Aug 12, 2002 5:58 am    Post subject: Rotax runs HOT!! Reply with quote
Im new to this also
Outside Temp 90
Jet 160
Eng temp 156
normal has been around 140
Is That ok?
Jim Marks
PostPosted: Mon Aug 12, 2002 10:11 am    Post subject: Rotax runs HOT!! Reply with quote
Thanks for all the help. After a couple weeks of head scratching, I was working on my Kart in the garage and noticed that the Mychron was on and reading 117 degrees Farenheit. The motor wasnt and hadn't been run. I took it to Pitts, turned it back on...118. Hooked up a new unit to my sender...95. It was the Mychron Calibration. Just got back from running Willow in 105. Rotax ran within range......
Andy Seesemann
Expert
Expert
PostPosted: Mon Aug 12, 2002 10:14 am    Post subject: Rotax runs HOT!! Reply with quote
Marks,
You're still alive?
ANDY
Nick Weil
PostPosted: Mon Aug 12, 2002 1:42 pm    Post subject: Rotax runs HOT!! Reply with quote
Please guys... Read your manual... or at least read the previous posts in this thread...
177 is hot...
155 is fine...
Nick
Gary Kannegiesser
PostPosted: Mon Aug 12, 2002 2:32 pm    Post subject: Rotax runs HOT!! Reply with quote
Nick Chill!
You were luck you got a manual!
The dealer we got our Rotax never gaves us any of that.
SSC has help alot. just to get us our passport.
I can read just dont have any thing to read.
Thanks for the info
Chad Stapleton
PostPosted: Mon Aug 12, 2002 2:38 pm    Post subject: Rotax runs HOT!! Reply with quote
Manual can be downloaded from the Rotax web site.
Bill Wright
PostPosted: Tue Aug 13, 2002 1:09 pm    Post subject: Rotax runs HOT!! Reply with quote
Manual can be downloaded from my web site. Look under the "parts" link. Also have the parts book there!
Bill Wright
"Get on Course!" with FK www.formulakart.com
SHAYNE SHIPLEY
PostPosted: Wed Aug 14, 2002 5:54 pm    Post subject: Rotax runs HOT!! Reply with quote
I'm glad Andy could help you at pitts,they are very familar with rotax karts and engines.
DB time: 0.148055 (43.06%), total time:0.343861, queries:37
