IKF Region 7 - LB
Top Kart USA - SS
Rotax starter ring came slack
Paul Mckay
PostPosted: Thu Jul 12, 2012 12:47 pm    Post subject: Rotax starter ring came slack Reply with quote
I usually have no issue with these but in my hurry to get the engine back together i did not put loctite on the crank. Anyway it came slack but he did 8 laps with it slipping and it has made a tiny grove / lip on the crank. You can feel it if you run your nail up the crank towards the engine casing.
Anyone ever had this, is it ok to dress the crank a bit then refit the clutch?
KZ10 Shifter. Awesome.
www.bmw535d.co.uk
Richard Thoms
PostPosted: Thu Jul 12, 2012 5:35 pm    Post subject: Reply with quote
dreaded "spun clutch" Evil or Very Mad
I'm surprised you got 8 laps with it like that, usually you lose all power transfer to the axle and just rev like crazy with no drive and pull over.
I always lap the clutch flywheel on the crank a bit with valve grinding compound anytime I install it. Although the book says to use something different I use the red loctite on the shaft and big nut. In 3 years of running I've probably spun the clutch twice and never had a problem getting the flywheel off when needed. Make sure to torque to proper specs.
Where are YOU Racing?
www.RacingWhere.com
The ultimate karting series/track/event directory!
Paul Mckay
PostPosted: Fri Jul 13, 2012 4:24 am    Post subject: Reply with quote
i was at work when my lads were racing. he said it only spun on one tight corner. Full revs nothing then jolted forward.
have not see the damage yet hopefully not too bad, bottom end brand new only done 30 mins Rolling Eyes
www.bmw535d.co.uk
DB time: 0.136914 (38.85%), total time:0.352395, queries:38
