IKF Region 7 - LB
K1 Speed - SS
DRT Racing - FB
Rotax Problem at the Start.
Goto page Previous  1, 2
james bremner
PostPosted: Thu Aug 01, 2002 8:10 pm    Post subject: Rotax Problem at the Start. Reply with quote
oil, the clutch!
Mike Robertson
PostPosted: Fri Aug 02, 2002 3:15 pm    Post subject: Rotax Problem at the Start. Reply with quote
We went out and run some test.
We get a very bad bog at 6500 RPM's
This stays till we get to 6700 RPM's and then it takes off.
But the bog lasts quite a while.
Mike Robertson
PostPosted: Sun Aug 04, 2002 7:21 pm    Post subject: Rotax Problem at the Start. Reply with quote
Well, we must have done something wrong.
Worked on it all day yesterday and thought we had it out, and sized the motor.
Guess we'll see what happens when it gets back.
Chuck Groat
PostPosted: Mon Aug 05, 2002 5:26 am    Post subject: Rotax Problem at the Start. Reply with quote
Mike - what changes did you make before the motor stuck? How far out did you go on the air screw?
Mike Robertson
PostPosted: Mon Aug 05, 2002 8:18 pm    Post subject: Rotax Problem at the Start. Reply with quote
Chuck,
I'll have to look at our notes. I'm not sure.
Funny, Jr. just said it was running great and a few laps later and it just stoped.
Checked the plug and it didn't look lean either.
David Killion
PostPosted: Mon Aug 12, 2002 6:35 am    Post subject: Rotax Problem at the Start. Reply with quote
I'm experiencing the same problem again. Early in my Rotax days I had this problem and fixed it with the needle position but the problem is back now and the needle is burried in the jet (clip position on top).
I'm going to re-stuff the exhasut (it's a 10 hour maintenance interval and mines got 25 hours)....we'll see what that does.
That sux that you stuck your motor, wish you better luck.
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
Page 2 of 2
DB time: 0.15935 (47.27%), total time:0.337113, queries:37
