2D2W - LB
Leading Edge Motorsports
Straight Line braking issue
Goto page 1, 2  Next
joey marshall
PostPosted: Wed Jul 11, 2012 11:46 am    Post subject: Straight Line braking issue Reply with quote
The kart kicks the rear end to the right under hard straight line braking.
Why? Could the axle be twisting and unloading?
The kart was scaled and all 4 corners were within 2lbs of ideal weight.
Thanks in advance
al nunley
PostPosted: Wed Jul 11, 2012 2:51 pm    Post subject: Re: Straight Line braking issue Reply with quote
Thanks in advance
As I remember, my kart always did the the same thing. Might have something to do with the dynamic unloading of the rear wheels when you get real hard on the brakes, even if the weights are the same on the scales.
Cory Milne
PostPosted: Wed Jul 11, 2012 7:44 pm    Post subject: Reply with quote
change your brake bios and bleed the breaks
Rodney Ebersole
PostPosted: Wed Jul 11, 2012 7:47 pm    Post subject: Reply with quote
Maybe it's the load developed from the left foot on the brake pedal.
Rodney Ebersole
joseph hollinger
PostPosted: Wed Jul 11, 2012 7:50 pm    Post subject: Re: Straight Line braking issue Reply with quote
Thanks in advance
What kind of kart?
Randy Mckee
PostPosted: Wed Jul 11, 2012 8:05 pm    Post subject: Reply with quote
+1
Same thing occurred to me with new chassis, which sadly resulted in a few off-track excursions. Had to bleed it over and over and it finally got the air bubble out.
Randy
Rodney Ebersole
PostPosted: Thu Jul 12, 2012 6:25 am    Post subject: Reply with quote
I read the post as he was working with a rear brake only problem.
Rodney Ebersole
joey marshall
PostPosted: Thu Jul 12, 2012 11:55 am    Post subject: Reply with quote
Rodney,
You are correct. It is a tag kart with rear only brakes. We did have to put some brake fluid in it after a day of running but I didn't see any fluid leaking from the system. We did have some smoke coming off of the brake rotor when we came in on one session. The kart is a Shockwave with Willwood brakes. I have a maranello chassis with brembo brakes and don't experience this issue.
Richard Thoms
PostPosted: Fri Jul 13, 2012 7:22 am    Post subject: Reply with quote
What direction is the upcoming turn? Does it kick right both into left and right turns? It does not take much of turn-in to upset the kart under very heavy braking especially if you have lots of caster and wide front end.
Where are YOU Racing?
www.RacingWhere.com
The ultimate karting series/track/event directory!
joey marshall
PostPosted: Fri Jul 13, 2012 8:52 am    Post subject: Reply with quote
The corner is a 90 deg left and yes the rear is kicking out to the right. We actually brought the fronts in to 45" from 45 1/2" and the caster is set at the medium setting which is working pretty well on most of the turns. We tried max caster but the kart was slower.
Richard Thoms
PostPosted: Sat Jul 14, 2012 9:20 am    Post subject: Reply with quote
So you are coming up to turn left and the kart is turning right on braking? (or the rear is going right - kart turning left?)
I wonder if it could be a stagger issue. Is this always a problem or just on recent set of tires? Maybe try swapping rear tires left/right and see if it kicks in the other direction??
www.RacingWhere.com
George Young
PostPosted: Sat Jul 14, 2012 8:28 pm    Post subject: brake problem Reply with quote
Make sure your chassis is squared up. Measure from the inside of the axle to the center of the spindle with the front steering pointed straight ahead. It should be the same measure on both sides, and of course have the proper toe setup. It could be a little out of square and when the brakes are applied the back end squares up???
george Y
Chris Livengood
PostPosted: Wed Jul 18, 2012 9:10 am    Post subject: Reply with quote
Widen rear track, reduce caster or jacking. Could be a driver anomaly.
http://www.Chrislivengood.net
http://www.Work-Racing.com
http://www.OurZeal.com
http://www.Karting101.com
Paul Makarucha
PostPosted: Wed Jul 18, 2012 9:35 am    Post subject: Reply with quote
Walk out on track, place level in same place the rear tires would be when you start braking, watch the bubble go to the right side of level.
CKR/KZ
CRG/ICA
http://Jaymotorsports.com
Mike Goebel
PostPosted: Wed Jul 18, 2012 11:32 am    Post subject: Reply with quote
Try Braking in a straighter line!
Mike G.
Closet KZ Lover!!!
mfg Technology Centre
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.087335 (42.47%), total time:0.205636, queries:38
