Ocala Gran Prix - LB
Top Kart USA - SS
Anyone else have problems with exhaust valve?
Mike Robertson
PostPosted: Fri Aug 09, 2002 7:04 pm    Post subject: Anyone else have problems with exhaust valve? Reply with quote
We just blew up an engine. Took it apart and it was obvious that the exhaust valve had been hitting ever so slightly the piston. Only problem was by the valve. This is the second case I've seen of this problem and that's with only 25 drives here.
Has anyone else had a problem like this?
Should it be covered under their engine warranty?
Marc Franck
PostPosted: Fri Aug 09, 2002 7:33 pm    Post subject: Anyone else have problems with exhaust valve? Reply with quote
How often are you cleaning your exhaust valve?
[ August 09, 2002: Message edited by: Marc Franck ]
Mikko Nassi
PostPosted: Fri Aug 09, 2002 7:45 pm    Post subject: Anyone else have problems with exhaust valve? Reply with quote
and you sure the valve is in the right way all the time?
As for have I had similar problems....nope, and this is the first I've heard.
Mike Robertson
PostPosted: Fri Aug 09, 2002 8:35 pm    Post subject: Anyone else have problems with exhaust valve? Reply with quote
Yes, Valve in the right way all the time. I know it looks like it ought to be the other way, but that is the way the manual shows.
The piston is perfect all the way around except where the exhaust valve is and there it looks like it has been scraping the valve.
And on signs of any lean condition either.
Charles Pou
PostPosted: Sat Aug 10, 2002 5:11 pm    Post subject: Anyone else have problems with exhaust valve? Reply with quote
Mike, with the powervalve installed properly, is the bottom of the valve flush with the top of the exhaust port (when fully open), or is there a lip?
Anyway, I thought the manual was pretty hazy on the proper way to install. :-)
DB time: 0.073122000000005 (42.08%), total time:0.173774, queries:37
