Bondurant - LB
Top Kart USA - SS
Franklin / Merlin USA - FB
Ballast
Eric Nelson
PostPosted: Fri Jun 29, 2012 3:44 pm    Post subject: Ballast Reply with quote
Does anybody know why the ballast rule is now written to require two bolts on a weight over 5 lbs? I heard this is a Rotax rule but I've never seen it required in SKUSA, IKF, WKA or anywhere else in karting. I'm building a kart with an XS seat and there's going to end up being so many weight holes for the surface area, experience tells me the fiberglass will tear between them. Then there will be a weight with two bolts, laying on the road.
Jason Vehige
PostPosted: Sat Jun 30, 2012 7:43 am    Post subject: Reply with quote
Eric,
Please write a request/letter here on the issue.
http://www.sebscca.com/
I could only guess that the rule came from a fear of someone hanging a 25 pound barbell weight with one bolt......
Jason Vehige
05 Vanspeed Sirio / SGM sl204
paul rees
PostPosted: Sat Jun 30, 2012 8:59 am    Post subject: Re: Ballast Reply with quote
Used aircraft counter weights . I don't know what they are made of , but are heavy for there size .
Jared Langenfeld
PostPosted: Sat Jun 30, 2012 10:17 am    Post subject: Reply with quote
I thought the rule has always been written as 1 5/16" grade 5 bolt per 5 lbs? I have 20lbs on the back of my seat with two bolts per 10lb weight, granted, I don't have an XS seat.
2008 Mike Wilson with Honda CR125 shifter
Tom Reynolds
PostPosted: Mon Jul 02, 2012 8:23 am    Post subject: Reply with quote
This was an item from the 2009 agenda just before I got on the KAC. I cannot tell what the triggering factor but I do know when it failed to make the 2010 rulebook, the SEB was very pressuring to make sure it appeared as quickly as possible in a tech bulletin. I cannot accurately comment if it was letter or incident driven.
Eric Nelson
PostPosted: Mon Jul 02, 2012 8:34 am    Post subject: Reply with quote
LOL thanks Jason, I'll do that. You're right, I've seen that one, 25 lb barbell weight attached with a single bolt in the center. Or duct tape even worse!
Now I can see how to get it done, with the block-type weights. The problem I am having is the customer provided the usual diving-type weights which are curved, the only flat portion is at the center. Two bolts there would be so close they would just tear through the "soft" seat I'm using. And bolting to the arced part of the weight will just crack the fiberglass.
Sorry, not trying to reinvent the wheel here... it just seems to me that it's much easier to tear the punctured fiberglass martix than it is to puncture it in the first place. Most rules I've seen don't require multiple bolts for 10 lbs, but rather require a minimum O.D. for the backup washer, to prevent the bolt head from pulling through. IKF requires the backup washer be metal.
Thanks again everybody!!
Joe Ricard
PostPosted: Mon Jul 02, 2012 12:47 pm    Post subject: Reply with quote
I really like Jared's solution. Those weights look real nice and clean. Might be the method I need to put 100 pounds on the Mini Max JA kart.
Is that a mini bread pan form.
Arrow AX-8/ Rotax Sr.
Ron Dodson
PostPosted: Mon Jul 02, 2012 1:01 pm    Post subject: Reply with quote
Can you melt down the diving weight and pour it into a more usable form?
Jason Vehige
PostPosted: Mon Jul 02, 2012 1:14 pm    Post subject: Reply with quote
FINALLY a topic where my weight is a good thing... no worries about melting lead or weight bolts.... Cool
Jason Vehige
Pax Rolfe
PostPosted: Mon Jul 02, 2012 6:48 pm    Post subject: Reply with quote
If you take a big hammer to those curved diving weights, they flatten out pretty quick. That's what I did when I remembered that lead is a pretty soft metal.
Pax
Tulsa, OK
Jared Langenfeld
PostPosted: Tue Jul 03, 2012 4:49 am    Post subject: Reply with quote
Yes, I used a mini bread pan. I started with a 20lb ingot of lead, took a wood splitter sledge hammer and drove that through the center to make two pieces of 10lb lead ingots, put the lead in the bread pan on top of a camp fire and the lead melted in about 10 minutes.
DB time: 0.126144 (38.37%), total time:0.32879, queries:38
