Ocala Gran Prix - LB
MRP - SS
SCCA Enterprises - FB
New Android application: Kart Chassis Setup
Inigo Sans
PostPosted: Fri Jun 29, 2012 3:16 pm    Post subject: New Android application: Kart Chassis Setup Reply with quote
Hi all,
I'd like to inform you that I've just published an Android application that will help drivers/tuners to setup the kart chassis.
The application analyzes some information provided by the user (cold and hot pressures, tyre temperatures and behaviour in corners) and provides some recommendations about which modifications you can do in order to improve the behaviour of the kart.
This is the description of the application that you'll find in the Market (Google Play): https://play.google.com/store/apps/details?id=com.isenet.kartchassissetup
Kart Chassis Setup is an application that will help you set up your kart chassis analyzing some information like tyre cold and hot pressures, tyre temperatures and behaviour in corners. Using all the data that you provide the application will give you some advices about how to adjust your chassis in order to resolve any set up problem that you're suffering. For each advice, you'll find an explanation about the adjustment. The explanation is usually accompanied by pictures to be more understandable.
The application is valid for sprint (road) karts and for all classes (adult or senior, cadet, junior). It's usefull for both experienced or novice drivers. For the former, it'll be a second opinion about what's wrong with the chassis setup, and for novices it will teach them the secrets of the chassis adjustments and chassis setup.
Pressure, weight and temperature measures can be used in metric or imperial units.
And finally, you can find some screenshots in the next links:
http://lh3.ggpht.com/FwDINxo6dd-S3HTt5znS-81K3WZIKkKSs3ERsfug1s8PRUh8ynD53Ks9eaX5pQe8GpM
http://lh3.ggpht.com/5K8JHEm_WaLYJKJAz5fpx4GekVwp6A4ZfdzdecU1ODDdPlymSNURIJn2WDFRFk0B2cJO
http://lh6.ggpht.com/CzX9Im3g9hOfUl_s5HXC3DvcpCvud4bauY_BfnYZys5hEr57Cqydz2JysjXmNBBJl04
http://lh4.ggpht.com/K8RVEB0sH2MyKxQyKccxnKsehCG-tqFSls5AfIRcGc2aG77eJOWbpXvXjo7v83PgAg
http://lh3.ggpht.com/xYRW9dRHkJWswvpwQVTeq_uK6XDS_jMHpCdO7fkeltEw2Ij5IG6I6nRa8aUOmsO9hJ-P
http://lh6.ggpht.com/ZZN1IntiMxPYDp6roiJ1-a6e_Q7m5CXM0Uk-8ROU601ADJnPpK7_PulcRjhRxHey-2k
http://lh3.ggpht.com/_bymquyqQkYPRy5X-hEoR0NM46Czd6l88q_Um5GvkCY6FlpUNMxlRpmhFIjx4dUyPbs
http://lh3.ggpht.com/Fb1Ts2qBJ39MuCnVBe5yI1jN_Ii0wxPAzzJPtUtK93UwP07HhxRczTZmvkfnYAGLTg
Please, send me any comment, doubt or suggestion about the application to android@isenet.es . I'll try to answer as soon as possible.
Best Regards.
Ray Lovestead
PostPosted: Fri Jul 06, 2012 2:17 pm    Post subject: Reply with quote
awesome! I've got a samsung galaxy and will give it a shot this weekend. Thanks for putting this together!
Ray
"Karting Expert Since 2014"
Matt Clark
PostPosted: Fri Jul 06, 2012 2:27 pm    Post subject: Reply with quote
any plans for iOS?
Inigo Sans
PostPosted: Thu Jul 12, 2012 11:59 pm    Post subject: Reply with quote
Matt Clark wrote:
any plans for iOS?
Hi,
It's on my mind, but I can't give you a date because I have too much work and projects.
Best regards.
Richard Thoms
PostPosted: Fri Jul 13, 2012 7:17 am    Post subject: Reply with quote
Looks like a nice app and professionally done. I'll give it a try next time out. Thanks!
Where are YOU Racing?
www.RacingWhere.com
The ultimate karting series/track/event directory!
Troy V Smith
PostPosted: Fri Jul 13, 2012 6:17 pm    Post subject: Reply with quote
Looks good Inigo! I tried it - looks pretty accurate - easy to use - Great for newer guys!
TVS Motorsports -
"We may not be the fastest on the track...
but we're having the most FUN!"
Justin Martin
PostPosted: Sat Aug 04, 2012 10:06 pm    Post subject: Reply with quote
Just downloaded it! Definitely worth the $7! I also downloaded the jetting app and ill have to give it a try too.
Damn good job!
Ill give it a try soon! Luckily I'll be dialing in a new kart sometime in a week or two!
DB time: 0.263572 (56.98%), total time:0.462608, queries:38
