MIR Racewear - LB
MRP - SS
SCCA Enterprises - FB
Novice question: How to seal up flex pipe, exhaust spitting
Jeff Spencer
PostPosted: Wed Jun 27, 2012 7:17 am    Post subject: Novice question: How to seal up flex pipe, exhaust spitting Reply with quote
New to the sport, I appreciate your patience, experience and advice.
I think I need to refresh the "wrap" around the flex pipe. Can I get what I need at a hardware store? Is that just fiberglass, & ?, are there good DIY alternatives.
Second question, how much is too much "exhaust spit"? It seems to me that we are getting a lot of blow by. For practice, I am running pump premium and 8oz per gallon of good 2 cycle racing oil, I think it is a Motul product. I guess I am asking if I went with 7oz/gallon, would that reduce the spit? Or if I use a higher octane racing spec fuel, will that make a difference? Also, would there be a noticeable improvement in performance and fussiness of the Gazelle?
jws
Steve O'Hara
PostPosted: Wed Jun 27, 2012 11:12 am    Post subject: Reply with quote
The type of gas and the amount of oil in your fuel mix is not the cause of the leakage at the flex. You are running the engine too rich on the carb settings or maybe just driving too passively. Avoid letting the engine idle or using part throttle as much as possible. Unless you are running in very cold weather you can just start the motor and GO.... no warmup needed. When driving the kart use full throttle or no throttle/brake to control the speed.... avoid part throttle even when driving in the pits.
Properly tuned and driven you won't need any cover at the flex as the exhaust will be dry.
Warning!! When you have a lot of residual fuel coming out the exhaust flex there is a high probability that you also have a buildup of residual fuel laying in the bottom of the crankcase and that can create some tuning challenges. It is pretty common for new karters to get their motor loaded up with residual fuel which makes the engine four cycle (blubber) and smoke a lot so they lean the jets beyond the correct setting and the engine will run fine for a while but eventually it will clean out the excess fuel and the mixture will be too lean and you'll need to re-adjust the carb or you'll damage the engine.
I would recommend you make sure the engine does not have a bunch of residual fuel by draining it. Just remove the spark plug and wrap the plug wire in a rag so it can't spark to any nearby metal, remove the fuel line and then flip the kart over so the spark plug hole is pointing to the ground and crank the starter for 10 seconds with the throttle wide open. The proceedure will blow any residual fuel out and you'll be able to start fresh knowing you don't have a small lake of fuel in the bottom of the motor.
I would also remove the pipe and dry out the header and the flex before running.
Good luck.
Steve O'Hara
Jeff Spencer
PostPosted: Thu Jun 28, 2012 9:36 am    Post subject: Reply with quote
Thank you, much appreciated. It sounds like you have some experience, I appreciate your willingness to help out.
I have a few follow up questions:
1. I have heard of folks running fuel mixtures of 6oz/gal -- 8oz/gal. What is a good mix?
2. I have researched and found that initial ballpark settings of the H L needles of 1 1/2 L, and 5/8 -- 3/4 H. From these initial settings, what would be a maximum amount of adjustment turning of each needle. What increments should the adjustments be made in. How does weather impact the adjustment of the settings?
3. How does pop off play into all of this? I have a gauge to measure this, but I have absolutely no clue.
jws
Paul Makarucha
PostPosted: Thu Jun 28, 2012 9:49 am    Post subject: Reply with quote
I use a PBR can myself.
CKR/KZ
CRG/ICA
http://Jaymotorsports.com
Jeff Spencer
PostPosted: Thu Jun 28, 2012 3:38 pm    Post subject: Reply with quote
Hmmm, PBR might be a little upscale for my for the way we roll.
jws
Jim White
PostPosted: Thu Jun 28, 2012 4:02 pm    Post subject: Reply with quote
jws
Theory is more oil will get you a little better ring seal and hence a little more compression. I run 8 in my Parilla Reedjet. I've run 6 but always end up back at 8. You will find that if you change oil ratios you will also have to change your needles as the amount of acutal gas going to the carb is now different. Pick a number and stick with it.
On a tilly carb I've found 1/4 turn on the needle is a pretty big change. I'd start with 1/16th to 1/8 adjustments. If you are unsure always go richer first. All you can hurt by going richer is a spark plug. Too lean and you buy a pi$ton. If he's really green and not hard on the gas off the corners lean the low a little to keep it running clean. Ideally I'd set the low so it just burbles just a bit coming off the corner then lean it just enough for it to stop burbling and run clean. For the high just get it to burble at the end of the straight and then lean till it just clears. If you have an egt gauge that records for you to look at later you can learn to tune much quicker.
As others have told you on the other forum the exhaust spitting mess is probably just because you are too rich. Thats not a bad thing for just learning. It's easier to clean it up than rebuild it. The wrapping is just header wrap from a speed shop.
For pop off do a search on this forum. Read a couple let it aborb than read some more. It's been debated endlessly since this forum started. Start with looking for posts by Mueller, Ohara and Nunley. They usually know of what they speak.
John Mulvihill
PostPosted: Thu Jun 28, 2012 6:44 pm    Post subject: Reply with quote
Hi Jeff,
Which motor?
John
I bowl overhand..........
Jeff Spencer
PostPosted: Thu Jun 28, 2012 8:30 pm    Post subject: Reply with quote
IAME Gazelle
DB time: 0.077821 (40.5%), total time:0.192127, queries:38
