SKUSA (non-flash) - LB
Ribtect - SS (non-flash)
Tony Kart/Vortex - FB
Clutch cleaning
Matt Clark
PostPosted: Tue Jun 19, 2012 6:09 am    Post subject: Clutch cleaning Reply with quote
Is there anywhere that describes in detail how to pull/clean the clutch in detail? Noob here who just ran his first practice day this past weekend and wanted to inspect the clutch but unsure of what all to do. I know the generic "pull and clean with brake cleaner" but to me that's a bit vague. Will I need any special tools? Thanks in advance.
Matt
Matt Clark
PostPosted: Tue Jun 19, 2012 3:54 pm    Post subject: Reply with quote
It seems I should have looked in the manual before posting Laughing Is there anything I can use if I don't have a piston stop?
Chris McGinley
PostPosted: Tue Jun 19, 2012 8:57 pm    Post subject: Reply with quote
If you're just looking to clean the clutch and clutch cover, there are several tools that will hold the flex plate. However, you can get away with a nice big flathead screwdriver - there is a small opening above the flex plate that you can lock the screwdriver into against the teeth of the flex plate.
If you want to remove everything, including flex plate (generally not necessary for normal maintenance), then you'll want a piston stop and puller.
sample tool if you go that route:
http://www.accelerationkarting.com/fixationtoolassy-1.aspx
Chris
Chris McGinley
Monster Raceworks
Rotax Masters
http://www.njkarting.org
http://www.btbsecurity.com
Matt Clark
PostPosted: Wed Jun 20, 2012 4:10 am    Post subject: Reply with quote
Thanks Chris. Stupid question, is the flex plate the plate labeled 1 on the Acceleration Karting diagram?
http://www.accelerationkarting.com/centrifugalclutchsprocket.aspx
Also, is there a certain kind of grease I need to use to grease the bearing? And it's red loctite for the outer nut correct? Thanks again.
Matt
Chris McGinley
PostPosted: Wed Jun 20, 2012 4:36 am    Post subject: Reply with quote
That's correct.... the flex plate is part #1 in that diagram.
For grease you can use wheel bearing grease. Some will push out when you put the clutch cover/driver gear on; remove the excess.
As for LOCTITE, use blue for the nut, not red. Torque it to 35nm.
Chris
Chris McGinley
Monster Raceworks
Rotax Masters
Matt Clark
PostPosted: Thu Jun 21, 2012 5:18 am    Post subject: Reply with quote
One more question about the screwdriver method, I'm guessing you're talking about sticking it in the opening that would be top-left if you're looking straight onto the clutch from the side. Do you guys usually put the screwdriver in vertically through that opening or do you put it perpendicular to the engine/clutch with the width of the blade spanning from the tooth to the opening and locking in there? Thanks!
Chris McGinley
PostPosted: Thu Jun 21, 2012 6:59 am    Post subject: Reply with quote
Put it in vertically...the handle should be straight above the clutch and the driver pointing down through that slot. Lean into it when you go to loosen/tighten the nut to avoid slipping.
Chris McGinley
Monster Raceworks
Rotax Masters
Matt Clark
PostPosted: Thu Jun 21, 2012 8:07 am    Post subject: Reply with quote
You the man Chris, any idea what size the nut is? I went to take off the drum last night but of course the I didn't have a socket big enough metric-wise and the one I'd need in standard must have walked out of my tool box Mad
Chris McGinley
PostPosted: Thu Jun 21, 2012 8:25 am    Post subject: Reply with quote
Thanks, but these were easy questions Smile
17mm is the size you're looking for
Chris McGinley
Monster Raceworks
Rotax Masters
Matt Clark
PostPosted: Fri Jun 22, 2012 4:45 am    Post subject: Reply with quote
Got it off last night (it was a bear to get off, a lot of cursing), hardly anything to speak of on the drum! Shot everything up with brake cleaner and put it back on. Used blue loctite on the outer threads of the nut and tightened down hard (don't have a torque wrench right now) so hopefully it's good to go. One thing I did notice after tightening is there seems to be a tiny bit of play in the drum, is this normal or does it need to be snug against the flex plate and the washer/nut combo?
Chris McGinley
PostPosted: Fri Jun 22, 2012 5:51 am    Post subject: Reply with quote
A little bit of play is normal.
Be careful about how hard you tighten this down; I've seen people break the end right off of the crank. You probably want to get yourself a torque wrench - I think the clutch drum, gear retaining nut, and flex plate nut may be the only things I use it for on my kart, but it definitely comes in handy.
Chris McGinley
Monster Raceworks
Rotax Masters
Matt Clark
PostPosted: Fri Jun 22, 2012 6:00 am    Post subject: Reply with quote
Yeah I'm going to be getting one, the only ones I had available were 50 ft/lbs. and up minimum so I just tightened it fairly hard and let it be.
DB time: 0.194257 (48.05%), total time:0.404319, queries:38
