SoCal Sprinters
Top Kart USA - SS
Tony Kart/Vortex - FB
BRC300cc Twin Video Link. Updated Sept 19.
Goto page Previous  1, 2, 3
Riley Will
PostPosted: Sat Sep 08, 2012 9:05 am    Post subject: Reply with quote
New video from last Thursday:
http://www.youtube.com/watch?v=7MzwchVxEBc&feature=youtube_gdata
Riley Will
BRC Engineering
rwill@brceng.com
(403) 216-0630 wk.
www.brceng.com
Riley Will
PostPosted: Wed Sep 19, 2012 6:38 pm    Post subject: Reply with quote
Ran our twin again today. We focused on chassis balance and tires. We tested 6" Superkart tires and 5" sticky tires. So much fun working chassis, the engines continue to impress and run like a top!
Very successful as we decided on the tire for the package and went out and lowered the outright track record that has stood for years. It was done by a 125cc shifter. We lowered it by 0.5 seconds. Even more impressive us that it was done on a green track and not at a major event with rubber down!
I think with more tuning we could go even faster:)
I will be posting up more video of today shortly.
Riley Will
BRC Engineering
rwill@brceng.com
(403) 216-0630 wk.
www.brceng.com
PostPosted: Tue Sep 25, 2012 8:59 am    Post subject: Reply with quote
Looking at the video seems like it comes off the turns a little soft. I know it has those low lock up clutches but are the carbs real big or the pipe a little peaky or were you going easy to avoid wheel spin? Seems like it comes on the power 1/3 down the straight. Doesn't sound like a twin on the video must be tuned pretty good together.
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
Pete Muller
PostPosted: Sat Sep 29, 2012 10:19 am    Post subject: Reply with quote
I think "soft" is probably deceiving in this case. Smile
That looks like a LOT of fun Riley!
PM
Chris Hurst
PostPosted: Sat Sep 29, 2012 3:30 pm    Post subject: Reply with quote
Hey Riley, been following the build since the thread was started. Pretty neat idea and good going breaking the track record. Curious if you guys have any dyno graphs or can describe the power band with some #s compared to the shifter that had the track record before you.
Also was the previous record for the shifter laid down in a race where the track had grip?
Just trying to understand how much more power you are working with. Any plans on road racing it?
Riley Will
PostPosted: Thu Oct 04, 2012 5:45 pm    Post subject: Reply with quote
Walt,
The bottom power off of the hairpin is soft compared to a shifter, but it takes about 20' off of that turn for it to plaster you like I've never felt before. I think it sounds the way it does (like a single) because the clutches are lock up types and not a typical high stall slider clutch type. It is deceiving on the video, John's driving makes it look easy. When the power valves open its like nitrous!
Pete,
It is awesome fun to drive. The part I have enjoyed is the building/engineering of it. Nobody does this stuff anymore and it's a shame:(. It does work really well and is very balanced.
Chris,
We are working with about 90-92hp. I haven't dynoed it together as we have an engine dyno now and sold the DynoJet dyno. We are using only 24mm ica carbs on it. 30mm KF1 carbs hit too hard!!! Our lap time was set on a green track. The previous was done by a 125cc kart under a 3 day event and great conditions.
It still revs past 15,800rpm and I want to lengthen the pipes again to gain more acceleration off of the slow turns and maybe limit the revs. The chassis and the engines are really tuneable. I think we still have another second left in it too.
Here are some video links from our last session:
http://m.youtube.com/watch?feature=plpp&v=BDyHIWp51Dw
http://m.youtube.com/watch?feature=plpp&v=bAIhn97FnO8
Hope you guys have enjoyed this as much as me.... Got another few projects being finished now, but the weather is getting cold up here.... Spring will be fun;)
Riley Will
BRC Engineering
rwill@brceng.com
(403) 216-0630 wk.
www.brceng.com
Jim McMahon
PostPosted: Thu Oct 04, 2012 7:33 pm    Post subject: Reply with quote
Hey Riley if you can find some KZ or other onboard footage from the same track I can put a side-by-side video together for you..
For sure looks like the thing is just getting warmed up.
Riley Will
PostPosted: Thu Oct 04, 2012 7:36 pm    Post subject: Reply with quote
James,
That was a KZ kart that John blew by.... It's a non contest;)
Riley Will
BRC Engineering
rwill@brceng.com
(403) 216-0630 wk.
www.brceng.com
Jim McMahon
PostPosted: Thu Oct 04, 2012 7:41 pm    Post subject: Reply with quote
Riley Will wrote:
James,
I get that, but some others don't. Was that a novice driver in the KZ?
Riley Will
PostPosted: Thu Oct 04, 2012 8:10 pm    Post subject: Reply with quote
Nope.... He goes own the straight as good as anyone that can pull gears.... Smile The 300 is just that quick!
Riley Will
BRC Engineering
rwill@brceng.com
(403) 216-0630 wk.
www.brceng.com
Jim McMahon
PostPosted: Thu Oct 04, 2012 8:25 pm    Post subject: Reply with quote
I was going by his body language but yeah the 300's got a little poke alright. How about a laydown version for the long tracks Smile
Chris Hurst
PostPosted: Thu Oct 04, 2012 10:08 pm    Post subject: Reply with quote
Riley Will wrote:
Walt,
Pete,
Chris,
Thanks for the info! Will you take it to any road courses? You should definitely go out to a big track and let this thing stretch a bit. Cool build.
Riley Will
PostPosted: Thu Oct 04, 2012 11:28 pm    Post subject: Reply with quote
How about a Superkart version that drives a separate behind the driver transmission????? Very Happy
Stay tuned....
Riley Will
BRC Engineering
rwill@brceng.com
(403) 216-0630 wk.
www.brceng.com
Tim Salvino
PostPosted: Fri Oct 05, 2012 7:11 am    Post subject: Reply with quote
Stay tuned....
Shocked
No way.
Shocked
Jim McMahon
PostPosted: Mon Oct 22, 2012 8:16 pm    Post subject: Reply with quote
Stumbled across a C-Open onboard video today. FUN..
http://www.youtube.com/watch?v=nk2b8zcC7YQ&feature=related
How about a triple?
http://www.youtube.com/watch?v=jdlXibX7IvU&feature=channel&list=UL
Page 3 of 3
DB time: 0.203533 (32.28%), total time:0.630515, queries:38
