Brett King Design
World Formula engagement issue
Chris Dorsey
PostPosted: Sat May 12, 2012 5:55 pm    Post subject: World Formula engagement issue Reply with quote
I've been having trouble with my daughter's World Formula and need some help from the experts. On take-off, under load, there is an intermittent grinding sound as the kart accelerates. During this time, the kart loses drive and then lunges forward, almost like the clutch is engaging/disengaging. The problem seems to go away once she is up to speed. I tried a new clutch and cleaning/rebuilding another clutch and the problem did not go away. I'm wondering if the problem is in the pull-start/recoil or starter units, but I'm just not sure where to start.
I would appreciate any help!
Larry Andrews
PostPosted: Sat May 12, 2012 10:39 pm    Post subject: Reply with quote
I had this problem once with a 13t #35 sprocket. Some of the smaller sprockets use thin bushings instead of needle bearings and do that when they lose lubrication and start galling. Some moly might fix it temporarily. New sprocket/bushing usually fixes it permanently.
It's not likely that the recoil starter is involved if it still works properly. The ears pop out when you pull the handle and retract afterwards - if they were stuck then it seems like there'd be a big mess and a non-running engine.
David McDowell
PostPosted: Sun May 13, 2012 9:15 pm    Post subject: Reply with quote
How do you have the clutch installed inboard or outboard, if outboard did you turn the shoes around since the clutch comes stock for a inboard configuration. I experienced the same jerky sensation until up to speed and the clutch fully engaged before I turned the shoes around.
Ron Carello
PostPosted: Wed May 23, 2012 3:01 pm    Post subject: Reply with quote
David McDowell wrote:
... , if outboard did you turn the shoes around since the clutch comes stock for a inboard configuration.
I saw your post before I set up my second WF clutch that came with my second WF engine from the manufacturer. I was curious to confirm the information because the paperwork specifically states "[t]he hub/shoe assembly will work in one direction only and needs to be installed properly. Clutch comes assembled to run 'outboard'."
Even though I run outboard and would normally just bolt it on, I took it apart to see which way it was setup. It was setup outboard.
Dean Graves
PostPosted: Wed May 23, 2012 3:15 pm    Post subject: Reply with quote
Interesting, in the past I've ran the clutch with yellow springs and ran inboard with the hub both ways. I found the hub configured outboard but running the clutch inboard ran very smooth.
Bernie Lacotta
PostPosted: Fri May 25, 2012 7:06 am    Post subject: Reply with quote
I've been told that putting the hub/spider ( for lack of a better description ) in opposite of the instructions allows smoother engagement. I tried it in three karts out of my shop and it certainly is much smoother , no jerking at all. BUT , after a three race test I noticed that there were signs of excessive heat in the clutch and of course the cause was excessive slipping. While engagement is smoother it does not "lock up" as it should . There was a documented loss of at least .5 sec. per lap and it would grow as the race progressed.
Note to Al Nunely : Yes , I know clutches don't fully "lock up"! What I observed and documented was excessive slip.
I breathe ,therefore,I race
David Klaus
PostPosted: Fri May 25, 2012 10:30 am    Post subject: WF Clutch Reply with quote
Chris,
I thing that you might look at to look is lower engagement springs. It sounds like the chatter you are experiencing is the clutch slipping while trying to engage. If you are on a tight track the engine rpm could be causing the clutch to go in and out of engagement.
Another option that Bernie describes is running the cartridge backwards so the shoes fight against the angle ofthe ramps while engaging. This will soften the engagement. It sounds like Bernie didn't have a positive experience trying this but a lot of our European community changes the springs AND flips the cartridge. Together these changes seem to be readily accepted.
You can run this clutch inboard. We don't suggest this simply because too many forget to use the radius washer and the force of locking the clutch down forces the assembly into the radius at the shoulder of the crankshaft causing the gear hub to possibly fracture. With this engine raced around the world this suggestion is to help eleviate a common error that costs racers unnecassary money. Done correctly you shouldn't have any issues.
DB time: 0.131144 (40.09%), total time:0.327104, queries:38
