Bondurant - LB
MG Tires - SS
Tony Kart/Vortex - FB
PRD Starter Button Mount
Eric Molinatti
PostPosted: Sun Apr 29, 2012 8:31 pm    Post subject: PRD Starter Button Mount Reply with quote
The steering wheel mount that comes with the kit is just not good.
What other ideas have you guys/gals come up with.
Pictures would be choice!
Thanks in advance!
Scott Heavin
PostPosted: Mon Apr 30, 2012 2:52 am    Post subject: Reply with quote
I don't have a pic handy, but I felt the same way so I did this:
Took a piece of angle aluminum (1" x 1" legs). Cut it to about 4" long. Drill out one side of it to accept the buttons and then drill a couple of holes in the other 'leg' for mounting holes. Then mounted it to the right hand side nassau brace so the buttons are in the up position and toward the center of the kart. All the wires reach easily and it's out of the way yet easy to reach. Be sure to round off all the corners just in case your knee gets up into it.
Spec TaG Masters @ NCMP / #23
Bret Moreland
PostPosted: Mon Apr 30, 2012 8:58 am    Post subject: Reply with quote
Here is a couple of photos of how I mounted my starter buttons. Just used some scrap metal and bent a bracket then attached it to the battery holder. Worked well on its first voyage to the track.
http://www.flickr.com/photos/34441120@N06/6982546950/in/photostream/
http://www.flickr.com/photos/34441120@N06/6982547060/in/photostream/
Bret Moreland
PRD Spec Heavy
TAG Heavy
RLV
A-BETT-ENT
Avanti MMK
bretzeke@aol.com
Eric Molinatti
PostPosted: Mon Apr 30, 2012 7:41 pm    Post subject: Reply with quote
Scott like this?
Scott Heavin
PostPosted: Tue May 01, 2012 2:51 am    Post subject: Reply with quote
Scott like this?
Yeah, Same concept - I just made mine. Simply drilled out the angle aluminum for each button, took them out of the steering wheel mount and attached them to what I made. My kart is at the track or I'd have a pic for you.
Eric Molinatti
PostPosted: Thu May 03, 2012 6:07 pm    Post subject: Reply with quote
I ordered this one from J3 mounts where the fuel tank screw goes in.
Ill post pictures once it is installed
Lawrence Doty
PostPosted: Thu May 03, 2012 8:20 pm    Post subject: Reply with quote
This is how I have ours mounted...for now anyway...
DB time: 0.203639 (49.02%), total time:0.415452, queries:38
