Brad Fish
Posted: Mon Apr 16, 2012 8:14 am Post subject: Shifter Rain Tires |
Our first event is this coming Sunday and of course, rain is predicted.
I've been shopping for rain tires and I'm surprised that there doesn't appear to be any 7.10 wide for the rear. Does everyone just run 6.00 wide on the rear in the rain? On what size rim?
Brad |
Joe Ricard
Joined: 23 Jun 2009 Posts: 868 Location: United States, Mississippi,
Posted: Mon Apr 16, 2012 9:36 am Post subject: |
Because you want 6's For rain wider is NOT better. _________________ Arrow AX-8/ Rotax Sr. |
Brad Fish
Posted: Mon Apr 16, 2012 9:54 am Post subject: |
We do something similar on our B-Mod car. Wasn't sure if the same theory applied when the wheels are only 6'-7" wide.
Do you run a 6" rim with a narrow track? I don't think my axle is wide enough to run the same track as with the slicks. |
Michael Taksa
Joined: 25 Jul 2001 Posts: 1395 Location: United States, Massachusetts, Boston
Posted: Mon Apr 16, 2012 10:12 am Post subject: |
| You want rear narrow front wide in rain. |
Jared Langenfeld
Joined: 06 Apr 2011 Posts: 65 Location: United States, Kansas, Kansas City
Posted: Mon Apr 16, 2012 10:20 am Post subject: |
I just went through this whole ordeal. I bought some rain tires, 4.5" front and 6.0" rear, and expected to be able to use the same wheels as I used for my dry tires, which are 4.5" front and 7.1" rear. Come to find out, 4.5" tires are mounted on 130mm wheels, 7.1" tires are mounted on 210mm wheels, and the 6.0" tires should be mounted on 180mm wheels. So I put a WTB in the ekarting classifieds and within a day I picked up a pair of 180mm wheels for $60 that matched the 130mm wheels I already had.
Bottom line, you need 180mm wheels for 6.0" tires. And 6.0" is the widest I have seen for rain tires. _________________ 2008 Mike Wilson with Honda CR125 shifter |
Alan Sheidler
Posted: Mon Apr 16, 2012 7:22 pm Post subject: |
| Michael Taksa wrote: | | You want rear narrow front wide in rain. |
As a general rule, that may be true. But, as always, some karts will not respond well to that setup, and each kart should be tuned to it's own best characteristics for rain days. The Renspeed does really well with something very close to the dry setup. Making the "normal" adjustments proved to bring on disastrous, nearly uncontrollable handling. Ask me how I know.....  |
Tom Reynolds
Joined: 08 Jul 2008 Posts: 555 Location: United States, New Mexico, Albuquerque
Posted: Wed Apr 18, 2012 12:10 pm Post subject: |
| I still have a used once set of rains on CRG/GP/etc bolt pattern wheels I'd let go for a steal if someone can use them is that helps anyone reading this. |
Joshua West
Joined: 25 Jun 2009 Posts: 46 Location: United States, Maryland, Salisbury
Posted: Thu Apr 19, 2012 9:09 am Post subject: |
Tom,
Send me a PM or shoot me an email at joshuajwest@gmail.com on those wheels/tires.
Josh |
