2D2W - LB
Russell Karting - SS
Tony Kart/Vortex - FB
JB - KT100 - WA55B or WB3A w/ .600 Restrictor Plate
Keith Burnett
PostPosted: Sun Apr 01, 2012 2:23 pm    Post subject: JB - KT100 - WA55B or WB3A w/ .600 Restrictor Plate Reply with quote
I have an 8 year old who will experience karting for the first time. He will be running SCCA JB. I have a KT100 with the WB3A carb installed, rules state I would have to add a .600 restrictor plate. Or, he could run the WA55B. I have the carb, just need the intake manifold and the filter adapter kit.
Is there a "better" option? Is one easier to tune/keep running?
Any help/discussion is appreciated.
Thank you.
Scott Boito
PostPosted: Wed Apr 04, 2012 7:57 am    Post subject: Reply with quote
If you get the WA55 carb set up, set it so it won't quite idle and won't quite stall when going off throttle at the end of a long straight. Then don't touch it. It's really a pretty good carb once you get it dialed in.
I can't speak to the WA3 with restrictor, but I imagine that it would be just as, or more, compromised than the W55.
Put a new plug in, set the WA55 to 1/8 turn on High and 2 1/4 turns on Low and try it out. Little movements can make big differences, so move in 1/16 type increments.
KM #68 - Haase/Honda kart
BetterOffRacing
Member of the SCCA KAC
Tom Reynolds
PostPosted: Wed Apr 04, 2012 9:26 am    Post subject: Reply with quote
I think most run/ran the smaller carb.
Richard Jung
PostPosted: Wed Apr 04, 2012 4:36 pm    Post subject: Reply with quote
Hi Keith,
We were the quickest JB KT100 at last year's nats, and the small carb works great once you learn how to set the 2 screws. At this point I would run it on the richer side to prolong engine life. Once he needs more power you can lean it out some. You''ll prob want a Mychron to monitor head temp/fuel mixture. I also found the the motor runs rich until it heats up, so I turn the low in for the first run.
Brian G. can provide much more info, if he sees this thread.
Rick
Keith Burnett
PostPosted: Wed Apr 04, 2012 7:06 pm    Post subject: JB - KT100 - WA55B Reply with quote
Thanks Guys...
So, I've decided to go with the WA55B.
I may see Brian G. this weekend, taking the kids the WDCR kart school, I think he is usually there. He has already helped me tremendously.
Thanks again.
DB time: 0.122891 (36.53%), total time:0.336443, queries:38
