Margay Racing
RLV - SS
KG Plastics - FB
Parilla Swift top end rebuild (JICA)
Goto page 1, 2, 3  Next
Kirk Deason
PostPosted: Thu Mar 22, 2012 2:01 pm    Post subject: Parilla Swift top end rebuild (JICA) Reply with quote
I was clogging up my previous topic of WB32 settings with my slow realization that the problem was not with the twisty bits on the carb. After testing the compression and finding *only* 55 or 60psi, I took the head off and found a stuck ring. I may have been able to simply clean the groove and put it back together but I went with a safer option and decided that a new piston and ring would be a better solution.
I measured the bore and came up with 52.39mm. After reading the Italian Motors' pdf and realizing that the bore came as a 52.40 from the factory i realized that my micrometer (or the operator) may be off a hair.
Claudio at IM helped me understand that a 52.40 red-dot was the piston I needed. It comes with a ring and circlips. I also purchased a new wrist pin bearing and all new gaskets.
Here are the goodies that arrived yesterday. Sorry about the glare:
Kirk Deason
PostPosted: Thu Mar 22, 2012 2:06 pm    Post subject: Reply with quote
I measured the base gaskets when I removed them. The second picture is hard to see but there was a paper thin base gasket that measured at .25mm and a thicker one at .50mm.
and
(I fixed the giant size pics)
Kirk Deason
PostPosted: Thu Mar 22, 2012 2:08 pm    Post subject: Reply with quote
The cylinder was unmarked and does not appear to need much attention.
and the bottom:
Kirk Deason
PostPosted: Thu Mar 22, 2012 2:10 pm    Post subject: Reply with quote
My finger is pointing to the spot on the groove where the ring was stuck
Kirk Deason
PostPosted: Thu Mar 22, 2012 2:13 pm    Post subject: Reply with quote
Pics of the head and combustion chamber.
Kirk Deason
PostPosted: Thu Mar 22, 2012 2:19 pm    Post subject: Reply with quote
Circlip before removal--but here is where I got stuck and stopped last night. After the circlips were removed, I expected the wristpin to slide out with just finger pressure. I was wrong. It didn't budge. I tried pushing on it with a plastic pen but that didn't move it. I did NOT hammer on it or tap it with anything as I did not want to damage the rod.
I thought about adding some heat to the outside of the piston and then pressing on it again from the other side.
Does anyone have experience with this? Previous tricks or tips for wristpin removal?
Jim McMahon
PostPosted: Thu Mar 22, 2012 6:10 pm    Post subject: Reply with quote
Sounds like the ring got gummed up alright, common enough with the nice smelling castor oils that get used in these motors. Looks like the piston is toast anyway with the dish in the center of it.
Like you said, if you heat the piston (I used to use a hairdryer) the wrist pin will push out. How is your main bearing axial and radial play? Did IM tell you what the squish clearance should be?
João Costa
PostPosted: Fri Mar 23, 2012 1:39 am    Post subject: Reply with quote
if you need some infos, i can tell you.
i have rebuild some engines like that and the last one i have made:
http://www.facebook.com/media/set/?set=a.296442357086232.69949.134690499928086&type=3
and if you make "like" on the Diabolicus page, you can follow many "threads" on karting themes
Wink
al nunley
PostPosted: Fri Mar 23, 2012 8:08 am    Post subject: Reply with quote
Not being an expert on that engine, I can only guess, but that piston looks to be a mess.
What are all those markings around the outside edge? Is it detonation? Is the piston hitting the head? If it is hittin, that can be cause by too little deck height or a loose bottom end. What oil do you use? I’ve seen that stuck ring problem when using synthetics, but if the piston is hitting the head, that could also cause a stuck ring. Have you checked the main bearings? Any up and down movement? More than .001” is a lot! You’ll need a dial indicator and a holder to check that. It’s real important to know. Main bearings do wear out.
How are you checking the bore? Not with the calipers I hope. A bore gauge is best, but expensive. Expanding manderails and a good micrometer, (.0001“) will do the job.
If you’re not an engine builder, I would let one take a look at that engine.
PostPosted: Fri Mar 23, 2012 8:27 am    Post subject: Reply with quote
Sometimes the wrist pin can move back and forth and push on the cir clip that raises a burr on the clip groove. You can try to remove the burr with a grinder but clean it good before pushing the pin. Try pushing it out by hand with a drift punch try both directions or very light taps with a hammer holding the piston by hand.
Put the piston a BDC. Put a piece of wood or metal between the piston skirt and the cylinder studs so the rod bearings are neutral then tap the pin out with a drift punch and hammer. If you think it's taking too much force then you need a wrist pin puller.
Don't forget to put the new ring in the bore and check for .012" end gap minimum.
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
Kirk Deason
PostPosted: Fri Mar 23, 2012 9:22 am    Post subject: Reply with quote
Thanks, Al and everyone else for your continued input.
--I never ran this engine before. It arrived in this condition and would not start-which led me to this point.
--I do not know which oil was used.
--Walt, Thank you, I did not know the end gap and yes I do have a new ring.
--I do not know what the marks are around the outside edge of the piston but they are not gouges or scratches.
--I included a close up of the head but it does not appear to be marked by impacts.
--there is very little side to side play in the rod.
--Yes I measured the bore with the calipers (I didn't know any better)
--No, I am not an engine builder (full disclosure)
--I will try the hairdryer removal method for the wristpin, first.
I can post more pics if you need closeups of anything.
Jim McMahon
PostPosted: Fri Mar 23, 2012 6:03 pm    Post subject: Reply with quote
My question was about the crank though, not the rod. Grab the crank at each side and see if you can move it up and down. If you can you may need to replace the main bearings. Some axial play (endfloat) is desirable, something around .008" (.2mm). To test this grab the crank and try to pull it side to side.
Al has a point about the missing carbon on the periphery of teh piston, sounds like it may have been just contacting the head at times. Some would argue that for racing its almost desireable if small, however for testing practice you dont want this. Squish clearance along with good bearings, including main bearings is what will influence this. You can make small adjustments to the squish with either base gasket thickness or head gaskets.
al nunley
PostPosted: Fri Mar 23, 2012 6:46 pm    Post subject: Reply with quote
Clear, up close pictures would be nice.
Myself, I would send the engine aout the first time so you can start out with an engine that is right.
There are a lot of people around that can do it. My engines alwasys went to Terry Ives in Folsom CA. 1-916-201-7707 He's been in karting almost from the start.
Jim Russell, Jr.
Advertiser
Advertiser
PostPosted: Mon Mar 26, 2012 12:33 pm    Post subject: Reply with quote
Looking at the pictures I agree that piston has been making head contact. This is not good at all. It will cause the stuck ring.
Causes-
improper machining
Improper assembly
too much wear on one or more parts in the rotating assembly
To push the pin out we use this tool
http://storefront.russellkarting.com:8080/storefrontCommerce/itemDetail.do?itm_id=3866&itm_index=0&orderQty=1
Our store can also help you with the parts that are needed. We can also do the engine work. Having been an IAME importer since its inception we can help you get the most out the engine within your desired results.
Jim jr.
Russell Karting
888-KARTING
Kirk Deason
PostPosted: Thu Mar 29, 2012 8:19 pm    Post subject: Reply with quote
The lower rod bearing is hosed. The rod play is more than excessive and it does not rotate smoothly around its complete stroke.
I think Jim Jr. nailed it when he said "too much wear in one or more parts of the rotating assembly"
I heated the piston with a hair dryer and with a few light taps with a drift and a very light touch with a hammer, the wristpin came out. Once the piston was removed and the wristpin bearing was out, I could get a good look and feel of the rod and main bearing. Verdict? Hosed. The movement that I was misinterpreting as the piston just being 'loose' was a toasted main bearing.
I took close ups of the piston which I will post tomorrow.
Page 1 of 3
DB time: 0.149676 (39.62%), total time:0.377769, queries:38
