SoCal Sprinters
MG Tires - SS
SCCA Enterprises - FB
DID 219 CHAIN
Kelly Kono
PostPosted: Sat Mar 17, 2012 9:37 pm    Post subject: DID 219 CHAIN Reply with quote
Has anyone had any experience with the DID Gold on Black chain? If so, what was the durability compared to?
Jim Russell, Jr.
Advertiser
Advertiser
PostPosted: Tue Apr 24, 2012 1:01 pm    Post subject: Reply with quote
We tested it many years ago.
The thing to look for with DID is that it is marked DHA. DHA is a hardening process. It is available on black/gold or all gold chain.
Both colors are also available as standard chains.
To answer the original question the black/ gold (typically non-DHA in US) will not last well on a Yamaha. Forget using it on a direct drive or TaG engine.
To solve any quality of product we use the RK chain. It is only available in the high quality type. IMHO it is better quality than any of the DID products.
Jim jr.
Russell Karting
888-KARTING
Kelly Kono
PostPosted: Tue Apr 24, 2012 9:49 pm    Post subject: DID gold and black chain Reply with quote
Thank you Jim
Robert Bujdoso
PostPosted: Wed Apr 25, 2012 6:36 am    Post subject: Reply with quote
I use the O-Ring chains for the TaG stuff. They're expensive, but gaurantee you wouldn't be replacing them often.
www.checkeredmotorsports.com
www.robertbujdoso.com
#32 PCR Driver
Cook Racing Engines
Steve Eady
PostPosted: Fri May 04, 2012 6:01 am    Post subject: chain Reply with quote
I agree, the RK o-ring is the best then the DID DHA. Both are good chains. Make sure you lube the DHA every time out with good quality chain lube.
Steve @ www.extremegokarts.com
"on-line store"
PostPosted: Tue Jun 12, 2012 12:18 pm    Post subject: Reply with quote
Jim, Which RK chain exactly? I'm looking for a non O-ring 219 chain. I did a search on your site but no joy.
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
Jim Russell, Jr.
Advertiser
Advertiser
PostPosted: Tue Jun 12, 2012 2:55 pm    Post subject: Reply with quote
link to standard RK chains.
https://storefront.russellkarting.com:8443/storefrontCommerce/search.do?searchType=itemNumber&keyword=RC-GB&emailAddress=&numResults=
Russell Karting
888-KARTING
Russ Deubel
PostPosted: Tue Jun 12, 2012 7:33 pm    Post subject: Reply with quote
Jim, whats a good sprocket to use for tag ? Is the steel sprocket longer lasting ?
Jim Russell, Jr.
Advertiser
Advertiser
PostPosted: Wed Jun 13, 2012 7:41 am    Post subject: Reply with quote
Personally I use the cheap sprockets. They are machined well and the material holds up fairly well compared to the US or Japanese products. At less than $15 they are a great value.
The steel sprockets last a really long time in running conditions. However they seem easier to bend than the aluminum due to the machining to make they light. If you don't drop off the track and always run the same teeth this is the way to go for longevity. Can last all year.
[url=http://storefront.russellkarting.com:8080/storefrontCommerce/breadcrumbSearch.do?breadcrumb_path=Russell+Karting%2f%2f%2f%2fUserSearch1%3dProduct+Number+%27xs-*%27&elementsPerPage=50&displayThumbnail=true&numResults=50&sort_type=ASC&sort_column=itm_num]cheap[/url]
[url=http://storefront.russellkarting.com:8080/storefrontCommerce/breadcrumbSearch.do?breadcrumb_path=Russell+Karting%2f%2f%2f%2fUserSearch1%3dProduct+Number+%27xs-*%27&elementsPerPage=50&displayThumbnail=true&numResults=50&sort_type=ASC&sort_column=itm_num]USA made[/url]
Steel
Russell Karting
888-KARTING
Michael Valiante
Advertiser
Advertiser
PostPosted: Thu Jun 21, 2012 8:35 pm    Post subject: Reply with quote
Kelly,
You should also note that chain tension is important with the RK since it is a little more difficult to set (O-ring). Make sure you move it up and down with your hand to get a good idea of the tension. Too tight and it will reduce the life of your sprockets and possibly reduce horsepower or cause chain bind. The RK as with the DHA stretch so after you run any new chain you will have to re-adjust for the second outing but you should be good to go after that.
The RK chain is pretty amazing.....
Michael Valiante
www.italianmotorsusa.com
Ihor Bilyy
PostPosted: Fri Jun 22, 2012 7:47 am    Post subject: Reply with quote
I had exceptional experience with CZ chain. It is 219 non o-ring and good price. Currently see it on KartSportNA (Arrow distributor) website.
DB time: 0.199774 (50.01%), total time:0.399472, queries:38
