jeff grose
Joined: 11 Dec 2008 Posts: 1249 Location: United States, Florida, cocoa
Posted: Wed Nov 07, 2012 1:05 pm Post subject: |
| Chris Reinhardt wrote: | | Greg Lindahl wrote: | | And be sure there's a gap between the screen and radiator so rocks will deform the screen before damaging the radiator. |
So how does that work in the center part of the radiator?
CR |
like i said in my post, i did mine with Stainless steel wire mesh and it works great,i did throw a rock at it as hard as i could and it barely left a dent on the wire much less the rad. _________________ jlgracing
#31 Gillard/PDBAmerica
IAME Leopards by P1 Engines
Tag Sr./FKCS/WKA
Driver: Jesse Grose
Remember: "No matter where you go,there you are" |
joseph hollinger
Joined: 12 Sep 2002 Posts: 9468 Location: United States, California, san francisco
Posted: Wed Nov 07, 2012 1:06 pm Post subject: |
How big was the rock? _________________ A lie gets halfway around the world before the truth has a chance to get its pants on. -- Winston Churchill. |
Joined: 29 Aug 2002 Posts: 2918 Location: United States, New York, Ossining
Posted: Wed Nov 07, 2012 1:39 pm Post subject: |
| jeff grose wrote: | | like i said in my post, i did mine with Stainless steel wire mesh and it works great,i did throw a rock at it as hard as i could and it barely left a dent on the wire much less the rad. |
I'll take it for what it's worth, but there isn't any support on the middle section of that screen, and wire mesh doesn't make a very good support member so unless you have a 1 inch gap between the screen and the rad fins, I don't think it much matters. Besides that screen that was suggested from Pegasus Racing, a 6x6 .035 ss mesh, is only about 60% open, meaning your $300 radiator is being starved of about 40% of it's airflow....
Just saying.....
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com |
Randy Mckee
Posted: Wed Nov 07, 2012 1:46 pm Post subject: |
| joseph hollinger wrote: | | How big was the rock? |
... probably throws like a girl. _________________ Randy
#123 TonyKart - S4 Stock Honda |
jeff grose
Posted: Wed Nov 07, 2012 5:10 pm Post subject: |
| Randy Mckee wrote: | | joseph hollinger wrote: | | How big was the rock? |
... probably throws like a girl. |
that's a good one Randy he'll be back for a second show at 9:00 pm
The rock size ? a little bigger rock than I hope we would ever see on the track  _________________ jlgracing
Tag Sr./FKCS/WKA
Driver: Jesse Grose
Cesar Rull
Posted: Wed Nov 07, 2012 7:28 pm Post subject: Pics of my installation |
This is how "low" I have installed to keep a LOG.
Bottom bracket without any spacers since I was able to slide the mount
Top Mount. Using 75mm bolt on CRG. |
Mike Goebel
Joined: 28 Jul 2001 Posts: 5763 Location: United States, California, Winnetka
Posted: Wed Nov 07, 2012 8:55 pm Post subject: |
It should be mounted up higher and out further.
mfg Technology Centre
Cesar Rull
Posted: Wed Nov 07, 2012 8:56 pm Post subject: |
| please explain why? |
Michael Boone
Joined: 31 Jan 2007 Posts: 1184 Location: France, Not USA state, Nantes
Posted: Wed Nov 07, 2012 9:56 pm Post subject: |
Your left arm will block most of the radiator when your in the seat and maybe a little higher so its in the direct air.
You've got the room to move it over!
Also your bolt on the bottom isn't long enough just a little longer so it goes past the nyloc.
MB _________________ If you can't keep up don't worry I'll be coming around again !
KZ 125 Masters
FFSA National race Director
http://www.ask-ancenis.fr/ |
Cesar Rull
Posted: Wed Nov 07, 2012 11:08 pm Post subject: |
Thanks michael, yes I agree I need to go back and get new bolt this week.
I will have to move it up a little more if I am going to bring it out more to clear the side pod. Too bad, I wanted to keep to as low as possible.
I have a question for anyone. Don't these radiators get damaged (corrosion) from using plain water? |
joseph hollinger
Posted: Wed Nov 07, 2012 11:13 pm Post subject: |
all the time. _________________ A lie gets halfway around the world before the truth has a chance to get its pants on. -- Winston Churchill. |
Cesar Rull
Posted: Wed Nov 07, 2012 11:19 pm Post subject: |
| ^ nothing we can do to prevent it / help the issue ? |
Kerry Matthews
Joined: 01 Oct 2008 Posts: 772 Location: United States, California, Sacramento
Posted: Thu Nov 08, 2012 12:07 am Post subject: |
| Cesar Rull wrote: | | ^ nothing we can do to prevent it / help the issue ? |
Use distilled water. _________________ Play now, work later! |
Spencer Uzri
Posted: Thu Nov 08, 2012 3:09 am Post subject: |
Drain the cooling system completely when you get home after a day at the track. I installed drains in the hoses at the lowest points in the system to accommodate quick & easy coolant removal, so it only takes ~3 mins to flush the cooling system. I got the 5/8" capped drain T's from a Prestone system flush kit.
Water Wetter (or similar), also provides some level of anti-oxidation protection & raises the boiling point. |
Jeff DeMello
Joined: 13 Sep 2002 Posts: 2213 Location: United States, Pittsburgh Pa,
Posted: Thu Nov 08, 2012 5:47 am Post subject: |
I think it was water wetter that I called and the said to run anti freeze then drain. They said it coats the alum radiator to prevent corrosion _________________ Jeff DeMello
Emmick F125 Pavesi |
