Ken Schilling
Posted: Mon Nov 05, 2012 7:41 pm Post subject: |
Cesar,
This is 1" 1/8" wall aluminum tubing you can buy an most hardware stores, cut to length. _________________ Ken Schilling
SKUSA Data Administrator
The opinions I express are mine alone and do not reflect those of any organization of which I am a member. |
Cesar Rull
Posted: Mon Nov 05, 2012 7:56 pm Post subject: |
thank you, at this point i am looking for some cassette bolts to connect the upper radiator support.
not sure what size (dia. ) the bolt is in terms of mm thread. I need to make a trip to ace hardware. i would really like stainless steel or rust resistant bolts.
on the bottom mount, at least in my case, it seems i can install the radiator mount without a space like you have. |
Randy Mckee
Posted: Mon Nov 05, 2012 8:57 pm Post subject: |
Cesar,
It may have already been mentioned in the 6 pages of radiator talk, but make sure you get some of that screen to put over the front and back of your radiator. Dirt, rocks, and David Hobbs' Klag will hit the rad fins. Without the screen in place, the rad fins will bend and you'll end up with a radiator that doesn't let much air through.
If unsure what screen I'm referring, go back to page 5 and Ken has some nice closeup shots. _________________ Randy
#123 TonyKart - S4 Stock Honda |
Cesar Rull
Posted: Mon Nov 05, 2012 9:15 pm Post subject: |
| thanks for the reminder. I also saw some manufacturer side/back covers. |
jeff grose
Joined: 11 Dec 2008 Posts: 1249 Location: United States, Florida, cocoa
Posted: Tue Nov 06, 2012 10:00 am Post subject: |
Cesar
got some stainless steel wire mesh for my son's rad., made 2 pieces for front/back and tye wrapped on the sides, looks great and saves the fins from damage, makes the rad. easy to clean also, simply made the 2 pieces large enough to fold over the side of the rad. then tye wrapped the 2 pieces down the side of the rad., 6 tye wraps holds in place  _________________ jlgracing
#31 Gillard/PDBAmerica
IAME Leopards by P1 Engines
Tag Sr./FKCS/WKA
Driver: Jesse Grose
Remember: "No matter where you go,there you are" |
Greg Lindahl
Posted: Tue Nov 06, 2012 12:04 pm Post subject: |
| And be sure there's a gap between the screen and radiator so rocks will deform the screen before damaging the radiator. |
jeff grose
Posted: Tue Nov 06, 2012 1:03 pm Post subject: |
| Greg Lindahl wrote: | | And be sure there's a gap between the screen and radiator so rocks will deform the screen before damaging the radiator. |
What Greg said +1
if got a little over 1/8" clearence between screen and rad. _________________ jlgracing
Tag Sr./FKCS/WKA
Driver: Jesse Grose
Tim Salvino
Posted: Tue Nov 06, 2012 4:04 pm Post subject: |
| jeff grose wrote: | 6 tye wraps holds in place  |
You want him to use TIE WRAPS on his kart??!!!!?!?!?!?!?!?
No way!!! Cesar, just go get that screen welded on there. No need for the cheap, easy way. That would be crazy. |
Sam Zavaglia
Joined: 23 Nov 2004 Posts: 1181 Location: Australia, Sydney,
Posted: Tue Nov 06, 2012 5:50 pm Post subject: |
| Randy Mckee wrote: | | If unsure what screen I'm referring, go back to page 5 and Ken has some nice closeup shots. |
That stuff also stops the mice from getting in.  _________________ www.samzavaglia.com |
Tyson Henry
Joined: 10 Aug 2011 Posts: 343 Location: United States, Texas, Arlington
Posted: Tue Nov 06, 2012 8:29 pm Post subject: |
| Tim Salvino wrote: | | jeff grose wrote: | 6 tye wraps holds in place  |
LOL  |
Spencer Uzri
Posted: Wed Nov 07, 2012 12:17 am Post subject: |
Personally, I slipped some woven cloth mesh underneath the vertical "slats" that run down the front/back sides of the rad. & have done fine with that. Considering the amount of flex that mesh wires have in them, an object with sufficient weight will impact & cause damage, irregardless of a few mm clearance. The mesh really helps dissipate & absorb impact energy.
joseph hollinger
Joined: 12 Sep 2002 Posts: 9474 Location: United States, California, san francisco
Posted: Wed Nov 07, 2012 12:22 am Post subject: |
Talk about overthinking things. It's a radiator. Get over it. _________________ A lie gets halfway around the world before the truth has a chance to get its pants on. -- Winston Churchill. |
Cesar Rull
Posted: Wed Nov 07, 2012 12:29 am Post subject: |
I went to homedepot tonight and got some longer bolts and some washers to install and mount the spike radiator.
Since the mounts can slide from side to side I did not need any of the spacers I was asking previously. I just lined up the radiator and bolted it on.
I noticed looking at several images online and a few cars at the track the people mount these radiators at different heights in relation to the frame let's say.
I mounted mine about 1/2" from the bottom rail and it is angled to match the seat for now which I would say its at a 45 deg. I know I am going to drive the car and see the temps and either lean it more toward the back or stand it up more. I figured I would want the radiator as low and possible. I also moved it away from the seat in a way to match where the motor is in efforts to "balance" things out a little bit. I do not have any clearance problems with the NA2 side pod.
I will take pictures of the weekend. Very nice radiator and mounts !!
The overflow bottle doesn't need to vent or does it?
How often to you guys refill you radiator? |
Michael Boone
Joined: 31 Jan 2007 Posts: 1184 Location: France, Not USA state, Nantes
Posted: Wed Nov 07, 2012 10:08 am Post subject: |
I check mine every time at home before I leave for the track!
Otherwise only if it gets hot!
MB _________________ If you can't keep up don't worry I'll be coming around again !
KZ 125 Masters
FFSA National race Director
http://www.ask-ancenis.fr/ |
Joined: 29 Aug 2002 Posts: 2922 Location: United States, New York, Ossining
Posted: Wed Nov 07, 2012 11:38 am Post subject: |
So how does that work in the center part of the radiator?
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com |
