DRT Racing - FB
Radiator options
Goto page 1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Brian G. Wilson
PostPosted: Sat Mar 17, 2012 3:45 pm    Post subject: Radiator options Reply with quote
I'm looking for a new, larger radiator, but I keep finding these ungodly expensive ones and I refuse to pay $400-500 for a kart radiator. Anyone have any options for a good quality radiator that is less than $300?
KEEP WORKING....millions of people on welfare depend on you !!
Steve Buckner
PostPosted: Sat Mar 17, 2012 6:09 pm    Post subject: Reply with quote
This is the one I went for. 16x10 with mount $330.00.
www.ellisracingproducts.com
Greg Lindahl
PostPosted: Mon Mar 19, 2012 10:37 am    Post subject: Reply with quote
Thanks Steve.
Kristian Werkley
PostPosted: Tue Mar 20, 2012 4:29 pm    Post subject: Reply with quote
I'm also lookin for another radiator right now and wanted to get some feedback, I've got a Spike and I've got an Ellis like the one above. They are both ok, but I want some extra capacity for the hot weather.
Anyone have any experience with the Champion Dual Core? That seemed like an interesting option.
Bernard Muminovic
PostPosted: Tue Mar 20, 2012 7:14 pm    Post subject: Reply with quote
Champion Dual Core is heavy. There's no way around this, you will need to spend $400-$500 for a larger radiator. Medium rads will not cut it when temps go over 90 degrees.
www.KartingConnect.com
www.neShifterKartSeries.com
www.facebook.com/neshifterkartseries
Steve Buckner
PostPosted: Tue Mar 20, 2012 8:52 pm    Post subject: Reply with quote
Most people i see buy the largest Rad and tape the crap out of it. HUMM, Wind sail. Have you ever tryed adding a shroud to duct the air thru the rad. I ran a single core Vortex with my Mod honda and I would see 140 to 150 max on a 100 deg day in So Cal. I would think you would want the smallest rad you could use without overheating it. Good for aero and you dont want that extra weight so high in the chassis.
Kristian Werkley
PostPosted: Wed Mar 21, 2012 5:37 am    Post subject: Reply with quote
Steve, I had a large shroud on the Ellis last year. I do see Ellis has some new sizes now, I think mine is one of the original 19x8's, kind of an awkward size to work with.
Bernard, I'm not looking for a medium rad. I would think the Dual Core weight would be similar to a large Champion, as it is smaller than the large but thicker.
Charles Kaneb
PostPosted: Thu Mar 22, 2012 10:45 am    Post subject: Reply with quote
1992-2000 Honda Civic radiator.
$55 at RockAuto.
13 5/8 x 13 1/2 x 1.
"If you're still in full control, you're not going fast enough" - Fred Frame
mike wallace
PostPosted: Tue Apr 10, 2012 3:32 pm    Post subject: Reply with quote
So how has that Ellis radiator worked for you,,
http://mancaveracing.com
Woodbridge Kart Club
DR Racing Kart
Brian Fisher Race Engines
Stock Honda
Spencer Uzri
PostPosted: Tue Apr 10, 2012 4:46 pm    Post subject: Reply with quote
$55 at RockAuto.
Economies of scale makes all the difference.
BTW, good luck fitting that one unless your seat is sized ultra-S.
Jeff Pickel
PostPosted: Tue Apr 10, 2012 5:11 pm    Post subject: Reply with quote
The radiator is part of the problem. You need to look at the whole system. I can cool a cr 125 on a 100 degree day at 100 degree water temp on a mod motor with jetting on the edge of deto. the radiator i use is a 14x10. It takes me about 10 hours to mod the whole system to work like it should. I have a cooling system dyno that i test all the parts on.
Brian G. Wilson
PostPosted: Thu Apr 12, 2012 10:19 pm    Post subject: Reply with quote
I'll let you know after this weekend.......
Shawn P. Hill
PostPosted: Fri Apr 13, 2012 8:20 am    Post subject: Reply with quote
Care to share what your setup is?
08 Mike Wilson Chassis - Mod Honda
Enzo Iadevaia
PostPosted: Wed May 30, 2012 11:19 am    Post subject: Reply with quote
I really like the KG radiators but dam are they expensive..
Luckily for me welding is no big deal.. So I'm using a Honda civic aluminium radiator which you can buy from ebay for less then 60 bucks..
http://www.ebay.com/itm/ALUMINUM-DUAL-CORE-2-ROW-RACING-RADIATOR-92-00-CIVIC-DEL-SOL-INTEGRA-EG9-EK9-EM1-/221024430500?pt=Motors_Car_Truck_Parts_Accessories&hash=item33761529a4&vxp=mtr
I'm modifying it so final measurements will be 16" tall by 9.5" wide.
I'll post up some pics when it's all done...
Spencer Uzri
PostPosted: Wed May 30, 2012 3:30 pm    Post subject: Reply with quote
Just receive my Ellis rad today. Scott really knows how to weld a nice bead. The mounts might even be overbuilt. They appear to be thick aluminum extrusions & the pivots at the radiator have rubber bushings. The thing just oozes quality.
Stoked, I am!
Page 1 of 9
DB time: 0.124593 (36.41%), total time:0.342154, queries:38
