SKUSA (non-flash) - LB
RLV - SS
SCCA Enterprises - FB
Tire question
Christopher Livengood
PostPosted: Sat Dec 15, 2001 7:02 am    Post subject: Tire question Reply with quote
I have heard that ygc's are a softer compound than the new yhc tire. If this is true do you think it would be a good idea to run the old ygc's on the front and the new yhc on the rear?
Patrick Hubbell
PostPosted: Sat Dec 15, 2001 8:34 am    Post subject: Tire question Reply with quote
quote:
Well you could do that but you would have an imbalance between the front and the rear grip wise. The YHC's are a little harder than the YGC's. You could use two different compounds in practice but for a race the rules would require that you use the same compound front and rear. Since the new tire is the YHC that is what you will need.
Gary Lawson
PostPosted: Sun Dec 16, 2001 9:27 am    Post subject: Tire question Reply with quote
So they won't let you mix the tires for the race or are you saying they won't let you run the ygc alltogether. I thought they were going to let you run either.
Chris,
Are you doing this in an attempt to loosen the rear or to get the front planted or both. What handling trouble do you usually have, tight?
Jimmy Moore
PostPosted: Sun Dec 16, 2001 2:56 pm    Post subject: Tire question Reply with quote
Some run ygb front and ygc rear, don't worry about it unless there's some rule against it.
DB time: 0.080095 (47.26%), total time:0.169489, queries:37
