SoCal Sprinters
Streeter - SS
KG Plastics - FB
tire wear
Joe Payne
PostPosted: Mon Dec 10, 2001 5:41 pm    Post subject: tire wear Reply with quote
I have a emmick enduro and the inside of the front tires wear more than the outside. the kart also pushes badly. What do I do.
Paul Harraka
PostPosted: Mon Dec 10, 2001 6:30 pm    Post subject: tire wear Reply with quote
add some positive camber. 1/2 degree to start with then more if needed.
Mark Dismore Jr
Advertiser
Advertiser
PostPosted: Mon Dec 10, 2001 7:17 pm    Post subject: tire wear Reply with quote
quote:
Also check your toe.
Joe Payne
PostPosted: Tue Dec 11, 2001 5:47 pm    Post subject: tire wear Reply with quote
thanks for the info.
Jimmy Moore
PostPosted: Wed Dec 12, 2001 6:35 am    Post subject: tire wear Reply with quote
Could be too much toe in. Get someone to check the toe while you're in the kart. Start with everything straight ahead and straight up while the chassi has you in it. As for the push, a common problem on a narrow enduro kart, move each rear wheel out a 1/2" and increase the pressure 1 or 2 psi.
DB time: 0.063092 (41.4%), total time:0.152388, queries:37
