OTK - LB
KG Plastics - FB
Lead Shock
Goto page 1, 2  Next
Brad Fish
PostPosted: Sat Mar 03, 2012 12:53 pm    Post subject: Lead Shock Reply with quote
I dug the scales out and weighed my son's JB kart for the first time. I'm having a very hard time wrapping my head around the fact that I need to put 70# of lead on the kart. That's 20# more than my son!
Thank goodness we're running a K80 or it would be worse.
Any advice on location, type, and fastening method for that much lead?
Does it have to be coated or can it be natural?
Scott Boito
PostPosted: Sat Mar 03, 2012 2:38 pm    Post subject: Reply with quote
Welcome to my world! Kieran weighed 50 with gear two years ago, when the K80 was still 250 lbs. His kart weighed almost as much as mine with the lead.
For the lead, I acquired various 5 lb "cupcakes" and use galvanized bolts and double nuts to secure. I add rubber washers to reduce vibration and protect the seat. Here's a pic of how the left side and rear look: https://sites.google.com/a/betteroffracing.com/www/videos/NJPro-2.jpg?attredirects=0
As for the distribution, generally speaking you want it toward the back, with weight distribution around 43% front and 57% rear. For us that meant a huge amount of lead bolted on to the seat and about 20 lbs on the floor board. Last year we moved up to the KT100 and a full-sized chassis and he only gained about 5 lbs, so again the weight was mainly added to the seat.
KM #68 - Haase/Honda kart
BetterOffRacing
Member of the SCCA KAC
Brian Garfield
PostPosted: Sat Mar 03, 2012 3:12 pm    Post subject: Reply with quote
The cakes are common to use, but if you can acquire raw bricks of lead from a manufacturer (that's where we got all of ours), it becomes a lot easier as it's more dense and you can cut/melt to whatever shape you want. Not sure if they'll sell to individuals anymore, but a place called OG Kelly in Tennessee was where I got mine. Back then, it was $1/lb.
BTW, if you have small kids, then JA will actually be worse than JB. Julian had 80lbs when he first started in JA. (never mind the fact that we have always had 80lbs on Lisa's)
Christian Hubbell
PostPosted: Sat Mar 03, 2012 9:57 pm    Post subject: Reply with quote
Think it's lead shot. Any who, melt some down into a baking pan outside. Beat it with a hammer to add some shape and it'll mount nice to the back of a seat with 4 bolts.
Brad Fish
PostPosted: Sun Mar 04, 2012 6:24 am    Post subject: Reply with quote
You are correct. It was a play on words since I'm in "shock" at how much lead I need to buy.
Attempting to be funny.
Christian Hubbell
PostPosted: Sun Mar 04, 2012 11:13 am    Post subject: Reply with quote
Got it now;)
I've seen people use lead sheets to make a removable seat insert, saves you from lifting an extra 15 pounds every time.
Matt Miskoe
PostPosted: Sun Mar 04, 2012 12:53 pm    Post subject: Reply with quote
Although I have not yet done it, someone gave me the suggestion of removing the rear bumper and filling the frame rails w/ lead shot. I have no idea how much weight you can hide in there or how hard it is to do/remove. I like the idea for how simple it is and that it keeps the weight down low. Not as good as concentrating it in the very center of the cart, but low is better than high.
F1 teams used to get spent/non-radioactive plutomium type materials because they are denser than lead, thus being able to concentrate the weight where they want it. You think lead is hard to come by...
Andrew Peppler
PostPosted: Sun Mar 04, 2012 1:53 pm    Post subject: Reply with quote
Weight up high is not bad for little guys karting, you want the frame to flex to work.. totally different from cars or F1 with suspensions.
I've got 60+lbs on ours, 40 on the back of the seat, 6 on the left side, 8 underneath the seat between the legs, and 10 lbs on the floor tray near the feat. Yes, it is heavy to lift.
I got my lead from http://www.divers-supply.com/Search.aspx?k=lead%20weight and painted them white per sprint race rules.
Tim Koyen
Advertiser
Advertiser
PostPosted: Sun Mar 04, 2012 3:10 pm    Post subject: Reply with quote
Matt Miskoe wrote:
Although I have not yet done it, someone gave me the suggestion of removing the rear bumper and filling the frame rails w/ lead shot. I have no idea how much weight you can hide in there or how hard it is to do/remove. I like the idea for how simple it is and that it keeps the weight down low. Not as good as concentrating it in the very center of the cart, but low is better than high....
This is never a good idea. The lead shot can move around, ruining your weight distribution. It also reduces the chassis ability to flex, plus it can get caked in there and make the chassis useless. Never mind the fact that in can spill on the track if a bumper bung pulls out.
My experience is to melt lead shot in a cast iron pan over a hot plate, or turkey fryer. Either way, do it outdoors. I found a cool cupcake pan that has posts in the middle to create a built in hole for mounting. Makes about 4.5lb pucks. Multiple smaller pieces are a better choice than one large one that will restrict the seat's flexing ability, which is key to making a kart handle correctly. I don't know about autocrossing, but in any other kind of kart racing, the weight must be bolted on and cannot be a removable "insert" of any kind.
www.kartlift.com
www.facebook.com/kartlift
Karl Hughes
PostPosted: Wed Mar 07, 2012 11:38 am    Post subject: Re: Lead Shock Reply with quote
We're using a bunch of dive belt weights with holes drilled through the middle for mounting. Check the rules (19.1 I believe) on mounting bolts - make sure you have the proper bolts properly secured (5/16 grade 5 with safety wire, locking nut, etc.)
Ours are mostly bolted to the seat back. Most of the weights we have are uncoated.
Joe Ricard
PostPosted: Thu Mar 08, 2012 6:25 am    Post subject: Reply with quote
We got smart about adding weight to my son's JB Birel C-28 (cadet)kart. Limited real estate with the smallest seat made.
When I looked for more room I custom made two pucks 3" dia and to the exact thickness of the bottom seat bolts. doesn't affect chassis flex and I was able to easily add 3 pounds in a place normally occupied by 3 ounce plastic spacers.
I an using an old Porsche air cooled cylinder as a mold. this way I can make a 1lb to 9lb puck just by changing the amount I pour in. We also have lead heal stops about 4 pounds each.
Then custom fit the piece under the seat crotch. hammered the snot out of it till it exactly fit the contour and also cleared the ground.
Then two 9 pound pucks up high on the seat back and a couple more 5's on the side aa well as lower seat back.
Yep that little kart is heavy.
BTW thanks for the 10 additional pounds to run the new restricted WF. Very Happy
Arrow AX-8/ Rotax Sr.
Dale Seeley
PostPosted: Thu Mar 08, 2012 4:16 pm    Post subject: Reply with quote
Write a letter....
Especially when the spec engine comes into play, a spec gear with a reasonable min weight makes a lot more sense.
Brian Garfield
PostPosted: Thu Mar 08, 2012 5:18 pm    Post subject: Reply with quote
You'll never win that argument until they tell the heavy kids that karting isn't their sport.
It's funny, we will be adding less lead to Julian's Spec Miata than the kart....less than HALF the amount.
Brad Fish
PostPosted: Fri Mar 09, 2012 9:06 am    Post subject: Reply with quote
I like the seat spacer idea. And the cylinder mold is brilliant. I have a small block Chevy on a stand in the garage. Guess I will finally put it to good use Laughing
I put my new shifter on the scales last night. 25# more lead needed there too! 100# between the JB and the shifter. I'm going to have more $$$ in lead than I will in tires!
Joe Ricard
PostPosted: Fri Mar 09, 2012 10:17 am    Post subject: Reply with quote
When I need lead I just make the rounds to all the tire dealers. I bring a couple plastic 5 gallon buckets. Usually they let me have all I can carry off.
Then my son sorts through the alloy weights and lead weights. I melt them down, pick out the steel clips and pour.
I have about 150 pounds of assorted pucks. still nothing to what Brain has I bet.
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.165661 (40.6%), total time:0.408075, queries:38
