Italian Motors - LB
Brett King Design
SCCA Enterprises - FB
125 chassis with rotax?
Brad Fleming
PostPosted: Mon Dec 03, 2001 7:28 pm    Post subject: 125 chassis with rotax? Reply with quote
Would a Trackmajic Diablo chassis be to stiff for the Rotax? With all of the chassis adjustments available, it seems like you could make it work after disengaging the front brakes. Does anyone have any ideas on this setup pro or con? I have the frame and was exploring my options, if there is any.
John Zimmer
PostPosted: Tue Dec 04, 2001 1:04 pm    Post subject: 125 chassis with rotax? Reply with quote
I'm running a Tony Mitox shifter chassis with a rotax engine next year. The guys at my shop think that's the way to go because the rotax does make a lot more HP than a 100cc kart. We'll see how that goes, but it seems to be a good match.
John
Mary-Ann Horley
Location: United Kingdom (Great Britain), not USA, Swansea
PostPosted: Fri Dec 07, 2001 9:24 am    Post subject: 125 chassis with rotax? Reply with quote
John, the two Mitox versions are the same apart from the brakes
Jeremy Laughlin
PostPosted: Fri Dec 07, 2001 9:38 am    Post subject: 125 chassis with rotax? Reply with quote
True Maryann,
But I think John was saying that a stiffer frame like the Mitox or the Diablo would be a better fit for a rotax engine, than a 100cc chassis would. Is this correct thinking?
DB time: 0.152257 (60.55%), total time:0.251441, queries:37
