OTK - LB
Leading Edge Motorsports
Binding Up
Christopher Livengood
PostPosted: Thu Nov 29, 2001 6:46 pm    Post subject: Binding Up Reply with quote
I was wondering what the opinions are on binding up? What are the solutions? I know you can add caster and know the effects of it. So lets just stick with basic seat position, verticle CG's and so on.
Drew Cleaver
PostPosted: Fri Nov 30, 2001 3:25 am    Post subject: Binding Up Reply with quote
Ways to loosen up would be softer axle, shorter hubs, moove the rear wheels out, take out a 4th rail if avaialable or rear torsion bar, and also basic aluminum wheels have seemed to be a bit more free then the cool looking mags or magnesium wheels.
Drew Cleaver www.vmaxracing.cjb.net
Randy Mckee
PostPosted: Fri Nov 30, 2001 7:47 am    Post subject: Binding Up Reply with quote
Christopher,
I have a binding up problem with my new Margay. I talked with my distributer and he said the seat should be lower (relative to the rear axle) than is suggested by the manufacturer. This implies, with all other measurements being equal, that leaning the seat back will lower the CG and lessen the binding problem. It should also loosen up the rear. I will be testing this assumption this weekend.
Asside from that, see the post about removing grip. Much of that will apply here.
[ November 30, 2001: Message edited by: Randy McKee ]
Mike Giessen
PostPosted: Fri Nov 30, 2001 10:34 am    Post subject: Binding Up Reply with quote
Drew, u know your stuff
PostPosted: Fri Nov 30, 2001 11:43 pm    Post subject: Binding Up Reply with quote
I know my stuff. Maybe not as well as you do, but better than alott.
PostPosted: Fri Nov 30, 2001 11:46 pm    Post subject: Binding Up Reply with quote
Binding up is not so much of a tight condition. Binding happens ussualy out of the turn as you chassis sets down. A soft axle and short hubs help but if your chassis is right, it will still roll freely throughout the the turn without these.
Gary Lawson
PostPosted: Tue Dec 04, 2001 3:40 pm    Post subject: Binding Up Reply with quote
You can also put in positive camber or go to a wider rim to reduce sidewall flex.
DB time: 0.176952 (43.54%), total time:0.40641, queries:37
