Adam M Kolesar
Posted: Tue Aug 14, 2001 2:20 pm Post subject: tire wear |
Hi my front tires wear more on the inside of the tire than the rest of it. Is this becuase of camber, a push or a chassis problem? I run a BRM MK5 Thanks Alot
Adam Kolesar |
Rob Hogenmiller
Joined: 20 Jul 2001 Posts: 850 Location: United States, Nebraska,
Posted: Tue Aug 14, 2001 3:07 pm Post subject: tire wear |
| Adam does the track you run on have lots of banked corners? I've found that banked tracks tend to eat up the inside of tires much quicker on the inside fronts more so than other tracks. |
Oscar Aguilera
Posted: Tue Aug 14, 2001 6:20 pm Post subject: tire wear |
| It could be a combo of camber and toe. Check out John's front end set up on this web sites tech section. |
Adam M Kolesar
Posted: Wed Aug 15, 2001 10:11 pm Post subject: tire wear |
| No Rob, there are no banked turns i run at oakland valley it has lots of tight turns,I have another question, is it worth it to purchase the exact toe? and does it help to know the exact toe and camber? |
Michael Taksa
Joined: 25 Jul 2001 Posts: 1393 Location: United States, Massachusetts, Boston
Posted: Thu Aug 16, 2001 3:38 am Post subject: tire wear |
| Adam, if you find any tools for toe/camber please let me know, I am running at OVRP also and have had problems getting my front end to work. I run shifter 125... Only 2 times so far. |
Adam M Kolesar
Posted: Thu Aug 16, 2001 8:57 am Post subject: tire wear |
| Michael I think i saw pictures of you at OVRP, I run there every week hopefully I'll see you there sooner or later. Another Question does anyone set camber a couple degrees positive on the stand to get it at zero on the ground? |
Doug Welch
Joined: 18 Jul 2001 Posts: 2402 Location: United States, state of mind, Somewhere
Posted: Thu Aug 16, 2001 10:59 pm Post subject: tire wear |
We adjust camber all the time to aid with tire wear and turn in and all kinds of other things. That is one of the good things about the DFM kart is the adjustability of the front end both caster/camber and acherman.
By all means, buy an exact toe or other tool to aid in the front end setup.
Doug |
Jimmy Moore
Posted: Wed Sep 05, 2001 5:25 pm Post subject: tire wear |
Your tire wear might be from a lack of side wall support. Try running more air pressure,
get wider wheels or run tires with a stiffer side wall. |
John Learmonth
Joined: 08 Aug 2001 Posts: 368 Location: Australia, N.S.W., Elands
Posted: Wed Sep 05, 2001 11:34 pm Post subject: tire wear |
Rob, on banked corners (and I have almost no practical experience on banked turns)the wear may be more on the inside of the treads than it will be on 'flat' corners because centripetal force is effectively making the kart / driver heavier (ie the 'G' force is pushing the kart harder against the track than gravity alone).
This will cause even more weight induced camber change (extra neg' camber) than you would normally see. Perhaps additional static pos' camber is what's needed to maintain a more even wear across the tread width? |
Steve DiVirgilio
Posted: Sun Sep 09, 2001 9:57 am Post subject: tire wear |
Adam, I have a BRM DK2 and just put camber pills in front, they make a huge difference and also plant the front end in the corners, set them all the way out, I think you'll like them. Steve  |
Darin Marcus
Posted: Wed Sep 19, 2001 6:39 pm Post subject: tire wear |
| ADAM!!! dude whats up? its darin, member me from norway? well how you been? how's ovrp? so you got a BRM now? how you like it? im still runnin margays, they are really hooked up lately, they are fast! well tell yer family i say hi and if you got aol or email or sumin, let me know, peace |
Joe Klenotich
Posted: Thu Sep 20, 2001 11:06 am Post subject: tire wear |
| Listen to Steve--put the pills in--especially for YGCs; YGBs seem to be a little better--run the fronts out to 3-31/2 spacers as well--good luck--try more pressure in the fronts--14 perhaps and adjust the rear to taste |
Paul Montopoli
Joined: 19 Jul 2001 Posts: 526 Location: United States, New Jersey, River Vale
Posted: Fri Sep 21, 2001 7:23 am Post subject: tire wear |
OK...I have the BRM DK3 and I just bought the camber / caster pills, but I am a little confused by what I should do with them. On some days, I have too much front grip which manifests itself in two completely different situations (problems described below).
Beside the other obvious adjustments (fronts wheels farther in, less pressure front, more pressure in the rear, longer rear hubs) I was thinking I would try to take some caster out and widen the front of the kart in an effort to find a more balanced set-up. My hypothesis is that my current setup is suboptimal insomuchas I believe the relationship between the front and rear track is out of wack -- front too narrow (2-2.5 spacers) relative to the rear (139.50cm or ca. 55"). All the other karts around here run super wide at the front.
What exactly are you doing to the front with the pills? I really an not having a problem with too much wear on the inside of the tire.
Here are the handling problems I have at times. At other times, the kart handles superbly. Can't really figure it out.
1. mid corner to exit slight lose of grip at the rear which causes the kart to get a touch sideways...loosing valuable speed accelerating onto straights
2. too much bite at the front causing the inside rear to lift uncomfortably high off the ground
Any ideas?
PM |
Keith Archambeau
Joined: 18 Jul 2001 Posts: 121 Location: United States, California, Chatsworth, Ca.
Posted: Fri Sep 21, 2001 8:40 am Post subject: tire wear |
Paul, sounds like you are right about the front being too narrow. Although all karts are different. I would try, Removing caster, widen front until push goes away. Then ajust rear bite with axel & hubs. If the front is still too hooked up the try lowering front ride height. Tighten or lossen front bumper for fine tuning. Good Luck
RACE! |
